can't boost over 10 psi for some reason (please help)
like the title says i recently install a kteller 3" exhaust don't have muffler yet and when i boost up it go's to about 13-14 and falls back down to 10 psi. What could be the problem help me out guys. thanks. All no matter how high i turn the boost it still does the same thing.
Re: can't boost over 10 psi for some reason (yeehonda)
Nothing at all has changed besides the exhaust? Did you remove the manifold/turbo for some reason? Possible exhaust or boost leak somewhere...
Im assuming before the exhaust you were boosting passed 10psi and tuned for it? Did you retune after the exhaust install?
Give us as much info as you can
Re: can't boost over 10 psi for some reason (IRONlung201)
where are you pulling your wastegate signal from. i was having the same problem when i was sourcing the signal from the intake manifold. switched to the before the throttle body and problem solved.
Hybrid96EK
01-06-2006 12:55 PM
