DSM Turbo Question
Old Oct 27, 2007 | 07:21 PM
wernhersey's Avatar
Default DSM Turbo Question
I am boosting my DA and wan't to know if will be able to get 10psi and 250whp out of a 2nd gen DSM turbo (TD04) and will this bolt up to my t3/t4 turbo manifold. Also is there away to do away with the internal wastegate. Oh ya, can I get an adapter plate to bolt this to my manifold. Thanks
Modified by wernhersey at 4:48 PM 10/28/2007
Old Oct 28, 2007 | 04:48 AM
wernhersey's Avatar
Default Re: DSM Turbo Question (wernhersey)
bump this up I gotta make a decision today.
Old Oct 28, 2007 | 07:17 AM
Schister66's Avatar
Man U FTW
You can make 250whp out of that turbo but its going to take more than 10psi....i dont get the significance of 10psi in this whole thing though
and no, it wont bolt up to your manifold
Old Oct 28, 2007 | 07:22 AM
OSK Automotive's Avatar
To not run the internal wastegate, get the flapper welded shut and run a external off your manifold.
Old Oct 28, 2007 | 12:48 PM
wernhersey's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">You can make 250whp out of that turbo but its going to take more than 10psi....i dont get the significance of 10psi in this whole thing though
and no, it wont bolt up to your manifold</TD></TR></TABLE>
From what I have read 15psi is about all that a stock b18 bottom end will handle and still be reliable. So I figured that 10psi will be conservative, and allow me to get the whp that I am shooting for. If this sounds foolish hit me up with some different ideas. Thanks guys
Old Oct 28, 2007 | 01:32 PM
TheShodan's Avatar
Moderator
Default Re: (wernhersey)
you can't go by strictly PSI. Different turbos give different volumes of air at the same psi. Look to what fits parts that are replacable in case something happens, or you need to swap out parts. Many B18b/c hondas can handle about 350whp reliably before items start breaking (and no I don't care if people here run 450whp on stock internals, it won't last that long..) My definiation of reliably long is 4+ years, so I keep it conservative.
Choose the turbo that works for your needs. The resources are out there. If you think this is going to be a nice reliable "cheap" setup, think again, and look to your budget.
Old Oct 28, 2007 | 03:11 PM
Schister66's Avatar
Man U FTW
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote"> you can't go by strictly PSI. Different turbos give different volumes of air at the same psi. </TD></TR></TABLE>
quoted just to reitterate that so you guys dont forget
Old Oct 28, 2007 | 06:22 PM
supabang's Avatar
its simple. if you want about 250whp with that certain turbo. start the tune low (say 8psi) then crank the boost up and tune till you get the desired power level.
Old Oct 28, 2007 | 07:23 PM
wernhersey's Avatar
Default Re: (supabang)
Alright. Thanks for the help guys. This is my first boost project and going to be my DD for the summer. This project is making me super nervous. Thanks again.
integlspwr2k
Oct 31, 2007 05:28 AM
beastda9
Feb 21, 2007 12:05 PM
mattssi
Aug 4, 2004 07:41 AM
whiteblurr
Jan 24, 2004 05:35 AM
94lsboost
Dec 18, 2003 10:37 AM
