car cutting out while getting on it
Old Oct 21, 2007 | 06:13 PM
1baddturbosi's Avatar
Default car cutting out while getting on it
my car was tuned on a 100 degree day in omaha with 91 octane pump gas. Its now about 45-55 degrees at night, it seems to cut out at about 6200 rpm. While i was racing a GTO (400hp) it cut out
What could be wrong??
BTW: i got my doors blown off TWICE
Old Oct 21, 2007 | 06:52 PM
SOHC_MShue's Avatar
Default Re: car cutting out while getting on it (1baddturbosi)
do you have boost cut? Its possible you are boosting slightly more in the cooler weather which is causing the ecu to cut fuel when it sees this higher than usual boost. You should ask your tuner if he set one. If not then it could just be an ignition problem. Denser air from the cold weather is going to require a stronger spark to bridge the gap on your plugs. You may need to tighten the gap between the ground strap and electrode.
Old Oct 21, 2007 | 06:57 PM
Default Re: car cutting out while getting on it (SOHC_MShue)
what should my plug gap be (around)??? im running 10psi off my tial wastegate spring.
I dunno if i have the boost cut set, ill findout 2morow
Old Oct 21, 2007 | 07:35 PM
SOHC_MShue's Avatar
It needs to be as low as it needs to be to not get misfires. I would start around .030 and work down from there. If you find that you have to gap it extremely low on that level of boost then you may just have an ignition problem in your distributor.
Old Oct 21, 2007 | 07:38 PM
the dizzy is new, it has 400 miles on it.
Old Oct 21, 2007 | 09:15 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1baddturbosi &raquo;</TD></TR><TR><TD CLASS="quote">the dizzy is new, it has 400 miles on it.</TD></TR></TABLE>
so what is your plug gap at? It sounds like it really could be boost cut though. Is it boosting anymore than it was in the warm weather?
What are your afrs as well? This would help narrow things down.
Old Oct 22, 2007 | 03:46 AM
sorry, its at my storage garage, i will let u know later today!!
Old Oct 22, 2007 | 07:05 AM
SOHC_MShue's Avatar
89edcivic
Mar 27, 2010 07:16 PM
1990si
May 14, 2007 08:47 PM
SpdFrk
Jul 10, 2004 12:07 AM
kid-honda
Apr 27, 2004 11:50 AM
CM-R
Aug 18, 2003 12:57 PM
