quick vacuum question
Old Oct 27, 2007 | 04:44 PM
xiLLtegRax's Avatar
Default quick vacuum question
just a quick question....
i have greddy 18g kit and i connected the WG line from the intake of compressor housing.... and also vacuum for BOV T'ed from intake manifold to pcv valve... because i dont have a nipple on charge pipe.....i personally thought it would work but i guess its a check valve so its not working properly??? did i connect the vacuum right and also which way would be better???
Old Oct 27, 2007 | 04:54 PM
xiLLtegRax's Avatar
Default Re: quick vacuum question (xiLLtegRax)
and please dont post saying i need vacuum manifold cuz im trying run this first until i get vacuum manifold.... thanks
Old Oct 27, 2007 | 05:02 PM
xiLLtegRax's Avatar
also how cold of spark plugs should i get??? any suggestions???
Old Oct 27, 2007 | 05:30 PM
boostedcivicsir's Avatar
Mr. Badwrench
is there a nipple on the compressor housing? if there is, thats where the wastegate goes, i like them there better.
as far as the BOV, teed into the PCV line is fine. its own vac source would be better.
Old Oct 27, 2007 | 09:57 PM
gsr x civic's Avatar
okay let me tell you what's up.
the bov should go straight to the pcv valve, and on that line, t it off and connect it to the wastegate.
IDK wtf you're talking about connecting the WG line from the intake of the comp housing.
those are some old pics of my previous setup. for the most part, that's how everything should look.
and how do you know it's not working properly?
btw, for the spark plugs, get NGK BKR7E's. great plugs. made 303 whp on them.
come back with more questions
Old Oct 28, 2007 | 09:04 AM
93supercoupe's Avatar
Default Re: quick vacuum question (boostedcivicsir)
yeah, when theres a nipple on the compresor housing, people usualy put that right to the wastgeate so it gets an early definet reading, w/o being messed up from 8 tees.
Old Oct 28, 2007 | 10:00 AM
xiLLtegRax's Avatar
Default Re: quick vacuum question (93supercoupe)
yea i would like to put the vacuum for the wg from the compressor housing but i do not have a nipple on it..... but for the cold side of turbo where you put on the filter i have a elbow with nipple so i put that there.... i think that works fine. but for the bov it doesnt really sound right... right now i have it connect to where pcv valve and intake manifold is..... i cut the hose off and Ted from it....
Old Oct 28, 2007 | 10:14 AM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xiLLtegRax &raquo;</TD></TR><TR><TD CLASS="quote">yea i would like to put the vacuum for the wg from the compressor housing but i do not have a nipple on it..... but for the cold side of turbo where you put on the filter i have a elbow with nipple so i put that there.... i think that works fine. but for the bov it doesnt really sound right... right now i have it connect to where pcv valve and intake manifold is..... i cut the hose off and Ted from it....</TD></TR></TABLE>
theres your problem.
there is no boost there.
only after the wheel on the compressor. like at the outlet or if there is a nipple in the housing. but is has to be after the wheel.
drill the outlet and put one there. thats what i do on them all.
Old Oct 28, 2007 | 10:22 PM
xiLLtegRax's Avatar
theres no boost there????? i thought its sucking in air from the intake of the turbo and gets boosted........ it doesnt seems like i have WG problem.... as far as i know..... whats the symtoms of WG problems???? (sorry new to boosting and trying to learn)...
Old Oct 29, 2007 | 03:43 PM
xiLLtegRax's Avatar
bump
Old Oct 30, 2007 | 04:01 PM
xiLLtegRax's Avatar
anyone?
Old Oct 30, 2007 | 04:16 PM
mitsuman's Avatar
You need to have it connected to a source AFTER the air is compressed(boost). Where the filter is, that is just air that is coming in that WILL be compressed.
Fix and let us know.
MurtazaDSM
Apr 8, 2012 09:10 AM
dAng! Kris
Apr 6, 2011 12:26 PM
b16a4
Oct 31, 2007 03:44 AM
.RTErnie
Dec 3, 2005 05:29 PM
quick gixxer
Jul 16, 2004 08:05 AM
