My setups potential hp?
Old Oct 24, 2007 | 04:38 PM
Will_H's Avatar
Default My setups potential hp?
ok im about to dyno my car heres the setup.
sleeved LS block
83mm CP pistons
Crower billet rods
Vtec head 1mm oversizeds valves on exhaust and intake side
CTR cams
Springs and retainers
Victor X intake manifold with 70mm TB
Top mount manifold
44mm WG
Tial 50mm BOV
3" DP
SC6152E turbo
1000cc injectors, with Walbro 255 intanke pump
What kinda power do you think ill put down? I was guessing around 550hp due to the fuel pump and the stock ignition. Any recommendations. Setup will be in a gutted CRX. thanks
Old Oct 24, 2007 | 04:48 PM
Schister66's Avatar
Man U FTW
Yeah, youre limited by the Walbro pump and stock ignition...550whp on race fuel should be possible
B18C1CYA's Avatar
Default Re: My setups potential hp? (MMMMMbaaaaaaaaaah)
I will say maxed out about 625 whp with cam gears and on race gas , the turbo and fuel setup will hold you back . I made 700+ whp on a stock ignition so dont waste your money on any msd stuff , if your going 2 put any money into your ignition or change it talk to tony1
Old Oct 24, 2007 | 04:55 PM
Will_H's Avatar
Default Re: My setups potential hp? (B18C1CYA)
thanks guys for the advice, i do have cam gears, but do you think ill be able to get more power out of the motor by retarding or advancing them? Also im doing a pump gas tune and a race gas tune.
Old Oct 29, 2007 | 05:39 PM
Will_H's Avatar
also added a FPR today not sure if that will really help though...
Old Oct 29, 2007 | 06:32 PM
Topdawgg's Avatar
500 on race gas no prob.. i wouldnt go too much higher then that... maybe 550.. I wouldnt push the walbro... although it CAN make around 600... doesnt hurt to be safe
CRXherbie91
Dec 8, 2012 01:10 PM
BlangBlangTEG-93'
Jan 16, 2007 05:58 AM
yee SERIOUS
Jun 14, 2006 07:20 AM
Jake92eg
Apr 26, 2006 07:55 PM
