SLS Mini Ram SOHC Users: Please HELP!
Old Oct 24, 2007 | 04:48 PM
sohczcturbo's Avatar
Default SLS Mini Ram SOHC Users: Please HELP!
Having a few issues with how low the turbo is hanging and running the return line. If some of you could post some pics to give me ideas it'd be greatly appreciated. Any mini ram will do, but preferably pics of SLS mini rams of sohc's of course. Thanks!
Old Oct 24, 2007 | 04:55 PM
DeadVet's Avatar
Default Re: SLS Mini Ram SOHC Users: Please HELP! (sohczcturbo)
I am having the same problem but with a b18. I am just going to cut the nipple on the bottom of the turbo so it gives it more of a slope.
Old Oct 24, 2007 | 06:01 PM
SD_Lurker's Avatar
HT White Ops
pm schister66 I am pretty sure he as a shorty.
Old Oct 24, 2007 | 06:08 PM
SLowCrx's Avatar
Im running into the same problem with my AFI mini ram ( that is if I ever get back to putting it together) .. Not really sure how Im gonna do mine some ideas would be great
Old Oct 24, 2007 | 06:15 PM
PSI2HI's Avatar
Former Vendor
Default Re: SLS Mini Ram SOHC Users: Please HELP! (SLowCrx)
You need to clock the center catridge, then what we do is run a 45 barb fitting right off the turbo into a straight barb fitting into the oil pan. There is enough room for a nice straight shot into the pan if positioned properly. I'll try and set one up tomorrow and get some pics.
Old Oct 24, 2007 | 07:30 PM
THEDirtyDseriesWOOT's Avatar
keep up the good work SLS...
Old Oct 24, 2007 | 08:02 PM
Default Re: (THEDirtyDseriesWOOT)
Don't get me wrong, it's a beautiful manifold, but the functionality isn't quite up to par. But oh well, I will figure it out, and make it a point I run their manifold. I will try clocking the turbo a tab. I have two 45's and a straight barb so I should be able to pull it off. Haven't tryed clocking the turbo yet because it's my "mach" turbo. It's a t3/t4 .50 trim. I ordered a new garrett t3 super 60 and it's on back order from garret but would be here any day I think? But I was thinking, more like hoping, the t3 super 60 will somehow sit a little higher, but I know that's not the case since they're both t3 housings lol, but let me wish damnit.
Old Oct 24, 2007 | 08:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLowCrx &raquo;</TD></TR><TR><TD CLASS="quote">Im running into the same problem with my AFI mini ram ( that is if I ever get back to putting it together) .. Not really sure how Im gonna do mine some ideas would be great
hmm... i think if you ditched the two 45's off the turbo and ran a single 90 you'd be good. I know it's the same angle, but it will take less space, which means it should bring your line up a bit. Keep the turbo clocked the way it is, just try a 90 on the housing then a straight on the pan. lol im running those same exact fittings! but I got two 45s and a straight. think I'ma clock the turbo, run a 45 and a straight.
Old Oct 24, 2007 | 08:44 PM
PSI2HI's Avatar
Former Vendor
I'll make a point to try get pics tomorrow of how we do the return line. I appreciate you bringing up this review, it helps us further customer support w/ installation. Maybe we'll have to offer an optional return line kit for the shorty manifold to make this a simple bolt on affair.
Old Oct 24, 2007 | 08:49 PM
Default Re: SLS Mini Ram SOHC Users: Please HELP! (PSI2HI)
lol I don't sound to sound like a dick or anything about it, I'm just having trouble with it, but I think if I clock the turbo it can be done. I really do like the manifold though. It's purty lol. I'm very satisfied with the product by all means. This isn't a big deal to me consider the head aches I've gone through this build. I know it can and will be over come, just gotta spend more than a hour on it lol. Had a few plans tonight so I couldn't get in "too deep". I don't think first dates entitle you to showing up in grease and oil on your hands lol. But if you post pics I'd be so so happy
Old Oct 24, 2007 | 08:53 PM
mrbsponge's Avatar
its ok to be a little low on the pan guys, remember oil is circulating thru the motor/pan/oiling system the whole time the car is running.
GREDDY's oil return is in the OIL DRAIN PLUG with a banjo fitting, this is no doubt the lowest point of the pan, and it is completely fine.
i know a greddy user who has had his return line in the oil drain bolt as the kit said to do, for over 60,XXX miles on a stock H22.
Old Oct 24, 2007 | 08:56 PM
Default Re: (mrbsponge)
I filled the oil pan with 4 qaurts of water to see where the "full" point is and made a line to see where it is. I understand the oil level drops with that car running, but I didn't want it to be backed up when I turned the car off either. But like I said, I'll get her figured out. I am just a ***** for looking at other peoples setups.
Old Oct 25, 2007 | 05:03 PM
Default Re: (sohczcturbo)
bump
Old Oct 25, 2007 | 05:27 PM
PSI2HI's Avatar
Former Vendor
Im currently out of our 45* pipe thread fitting otherwise i would have posted pics today installed. If your still lookin when they show up i'll post pics.
Old Oct 25, 2007 | 05:36 PM
Default Re: (PSI2HI)
always looking lol
pics would be great to give me an idea.
Old Oct 28, 2007 | 04:25 PM
bumpidy bump.
Jeeze wish SLS would post them pics of their setup
Old Oct 28, 2007 | 06:01 PM
JaredKaragen's Avatar
ya, my drain line is kinda long, gives a little pooling area, but is not an issue... that is a little low though. I agree with clocking your turbo to a 45 degree with the drain towards the pan, I had to do mine opposite.
Old Oct 29, 2007 | 01:18 PM
evokidvii's Avatar
Default Re: SLS Mini Ram SOHC Users: Please HELP! (JaredKaragen)
bumpin it up, because im pretty sure im about to run into the same issue
Old Oct 29, 2007 | 01:21 PM
PSI2HI's Avatar
Former Vendor
Default Re: SLS Mini Ram SOHC Users: Please HELP! (evokidvii)
Clock the center section of the turbo and use a 45 fitting off the turbo and it plumbs right into the pan.
Old Oct 29, 2007 | 03:55 PM
y7turbo's Avatar
could save some space by using a return flange with the -10 male fitting right on the flange.
Old May 10, 2008 | 11:28 PM
Rtboy10's Avatar
use a spoolin performance log manifold
Old May 11, 2008 | 12:02 AM
CoreyR's Avatar
Default Re: (Rtboy10)
how many old threads are you going to post in tonight? i already see about 15 on the first page with you being the last poster
Old May 11, 2008 | 12:30 PM
Quad-Damage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtboy10 &raquo;</TD></TR><TR><TD CLASS="quote">use a spoolin performance log manifold</TD></TR></TABLE>
bb_SI
Jan 21, 2007 06:08 AM
BoostedEgHatchFl
Oct 23, 2005 04:50 PM
-JSpecEk*9-
Aug 21, 2005 08:49 PM
juicedricer
Nov 6, 2002 04:35 PM
