Ku engineering version 2 intake manifold
Found this when browsin for an intake manifold and the 75mm TB for my build. I am going to be doing a 300+whp daily turbo build - 400+ tracktime. I am thinkin I may give this a try. For tubo I am thinkin this may be very beneficial. What you all think? What kind of issues can I expect to see do to not having all the OEM sensors?
http://cgi.ebay.com/ebaymotors...wItem
its probably mirrored(sp).
Yeah, really, for the prive and the power u wanna make, theres better options.
And really, at 400HP, an IM isnt that nescary.Id rather have a b16 IM and CTR cams w/ the 400 hundred u didnt spend on that.
http://www.japengineshop.com/
Just had a look through this site that sells KU products. Why that manifold not listed anywhere?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe »</TD></TR><TR><TD CLASS="quote">its probably mirrored(sp).
And really, at 400HP, an IM isnt that nescary.Id rather have a b16 IM and CTR cams w/ the 400 hundred u didnt spend on that.</TD></TR></TABLE>
I really don't think I would ever buy it, I was just wanting to get other opinions on it.
I thought it looked decent and wanted to see what others thought of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Fanatic »</TD></TR><TR><TD CLASS="quote">IACV - IAT - not sure but maybe others'</TD></TR></TABLE>
you will not be able to run an IAC... rough and high idling that you'll have to sacrifice unless you can disable that sensor...
edlebrok is my choice... simple and big..iac compatible, etc etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEEYOND »</TD></TR><TR><TD CLASS="quote">you will not be able to run an IAC... rough and high idling that you'll have to sacrifice unless you can disable that sensor...
I sent you a PM!
Thanks
</TD></TR></TABLE>I sent you a PM!
Thanks
DragInteg
May 4, 2004 09:15 AM
