Missing bad in boost and higher RPMs
Old Oct 23, 2007 | 06:02 AM
LST2's Avatar
Default Missing bad in boost and higher RPMs
I am getting major misfire above 5000 RPM and above 1bar boost. I have run into this probelm before and last time it was caused by the VTEC not switching over and the non-VTEC map not being tuned very well. However, this time VTEC is definately switching over as I can hear it in the exhaust note. I just changed my plugs and gapped them down to .025 with 8 step cold NGK Vpower plugs. It is almost as if the VTEC cam lobe is switching but maybe it is still using the non-VTEC map. AFR is good... right around 11.5.
I am going to try and take the boost down to .5bar and work my way up to see if it starts breaking up at a certain level of boost. I am not getting the misfire if I go part-throttle and rev it out.
Any ideas?
Old Oct 23, 2007 | 06:13 AM
TurboLSVtecTeg's Avatar
Default Re: Missing bad in boost and higher RPMs (LST2)
What ignition setup do you have on the car and what do the plugs look like? It could be a ignition timing or plug gap problem.
Old Oct 23, 2007 | 06:40 AM
LST2's Avatar
Default Re: Missing bad in boost and higher RPMs (TurboLSVtecTeg)
Ignition:
Stock Distributor
MSD Cap
MSD Blaster Coil
MSD Plug Wires
FYI... I did not make a change to my ignition setup... I just all of a sudden started running into this misfire probelm
Plugs:
Just put new plugs in... last ones looked a bit rich but I had not changed them for a while and the plugs tend to foul out after about three months.
Timing:
Did not change timing when the missfire started
The only big thing I have done was change the clutch. I may have bumped a wire or messed up a ground somewhere when I took the tranny off.
Old Oct 23, 2007 | 07:47 AM
FaceTuned's Avatar
try to bring the gap down on the spark plugs.
Old Oct 23, 2007 | 10:40 AM
LST2's Avatar
Default Re: (FaceTuned)
Smaller than .025? I have searched around and saw a few people going as far as .020-.022.
I am running a T3/T67, high boost is 25psi with methanol injection so maybe .022-.023 would be better for me. Strange thing is that .028 used to work fine, that is why I dropped it down to .025 with the plugs I just put in.
Another thing I was thinking of is maybe one of my injectors is cloged. My idle is perfect and engine sounds good cruising around town.
Modified by LST2 at 12:08 PM 10/23/2007
Old Oct 23, 2007 | 03:26 PM
LST2's Avatar
Default Re: (LST2)
Update:
Haven't closed the gap yet on my plugs but I did lower the boost level. It looks like it is not RPM or VTEC related b/c I am not missing on lower boost levels at full throttle. Seems to start breaking up at around .9Bar. My AFR seems to have gotten a little rich too... about 10.5. I am going to lean it out a little and see if I can up the boost. Seems like I am eigther too rich or plugs need to be gapped smaller. We'll see tommorow.
I should also check the grounds since this started hapenning after I took off the tranny. There are two major grounds right? One on the transmission wire braket thingy and the other on the thermostat? Any others?
Modified by LST2 at 4:37 PM 10/23/2007
Old Oct 23, 2007 | 05:10 PM
lkailburn's Avatar
which map sensor is this?
-luke
Old Oct 23, 2007 | 05:18 PM
LST2's Avatar
Default Re: (lkailburn)
GM 3bar
Old Oct 23, 2007 | 05:47 PM
Runnerdown's Avatar
Sounds like ignition problems. Usually at higher boost and rpm. distributor, coil etc....
Old Oct 23, 2007 | 06:15 PM
NJIN BUILDR's Avatar
Default Re: Missing bad in boost and higher RPMs (Runnerdown)
I chased a similar problem for a while.I fixed a lot of small problems but it was a new (used) igniter in the distributer that cured the problem.Ran great on the street but wouldn't turn over 6K at the track under power.
Old Nov 17, 2007 | 05:29 AM
LST2's Avatar
Default Re: Missing bad in boost and higher RPMs (NJIN BUILDR)
Well I somehow fixed the problem by changing a few things. I thought is was gapping the plugs smaller. It worked for a while but now I am misfiring again. I tried gapping the plugs closer and now it is down to .020.
The only other thing I did was recharge by battery which went dead. Another thing I noticed is that my lights are really dim, so dim that I can see my car cast a shadow from the cars lights behind me. I am wondering if I have a problem with my alternator, battery or bad ground and that is causing a weak charge to the coil and thus the misfire in high boost. I am going to Autozone to get my alternator and battery tested and I am going to clean up all my grounds. Could this be a potential cause of the misfire?
Old Nov 17, 2007 | 07:30 AM
boosted k20's Avatar
did u clean up ur a/f? u said u changed the clutch. maybe u didnt put one of the boost clamps on good. i did that to my car when i changed my clutch. the car was running way richer. turned out i had a boost leak (even though i was still getting the same psi on the guage)
Old Nov 17, 2007 | 07:58 AM
LST2's Avatar
Default Re: Missing bad in boost and higher RPMs (boosted k20)
A/F is all good 11-11.5. I did put in a new clutch. I don't think I have a boost leak as I was able to get rid of the missfire for about two weeks. During that time I was able to hold a steady 27psi. The missfire just came back.
Old Nov 17, 2007 | 08:13 AM
bigb16's Avatar
Does it do it when the car is still cold?
Mine was doing the same thing. Full throttle at full boost, I would get a misfire, but only when the engine is hot after a 15 minute drive.
I changed the ICM (ignition control module) in the distributor, and the misfire went away. Autozone has the part for $65.
Old Nov 17, 2007 | 08:20 AM
Snailed EF's Avatar
Default Re: Missing bad in boost and higher RPMs (bigb16)
was there a retune after vtec was fixed?
Old Nov 17, 2007 | 09:48 AM
LST2's Avatar
Default Re: Missing bad in boost and higher RPMs (Snailed EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigb16 &raquo;</TD></TR><TR><TD CLASS="quote">Does it do it when the car is still cold? </TD></TR></TABLE>
I am not sure. I try not to boost hard unless the card the warmed up. I hear it is bad to boost if the oil is not warm yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigb16 &raquo;</TD></TR><TR><TD CLASS="quote">I changed the ICM (ignition control module) in the distributor, and the misfire went away. Autozone has the part for $65.</TD></TR></TABLE>
Thanks, I'll add that to the list of potential fixes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snailed EF &raquo;</TD></TR><TR><TD CLASS="quote">was there a retune after vtec was fixed?</TD></TR></TABLE>
Yes
Old Nov 17, 2007 | 12:17 PM
95exdsmkilla's Avatar
check your wires make sure they fit.
I had the same problem and it was just spark plug wires.
Old Nov 17, 2007 | 08:07 PM
bigb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LST2 &raquo;</TD></TR><TR><TD CLASS="quote">I am not sure. I try not to boost hard unless the card the warmed up. I hear it is bad to boost if the oil is not warm yet.
I didn't mean cold, but I meant not-very-hot... I would never even move until my car gets up to running temps.
Old Nov 18, 2007 | 09:48 AM
LST2's Avatar
Well, I think I found the problem. I went to check my alternator and battery and the alternator was pumping out 14v+ so it was OK. But, when they put a load on it the car died. Turns out my battery is toast. This kind of makes sense as the misfires stopped for about a week after I recharged by battery at home.
I have not done a high boost run yet so not sure if this fixed it. I am out of town for a few days so I'll post back on Wed with results.
Old Nov 21, 2007 | 02:01 PM
LST2's Avatar
Well that was not it. Back to the drawling board. Going to change the plugs again. Also, I am going to see if it has somehting to do with my meth/water setup. I could have potentially mixed in too much water last time, and b/c I inject a lot of the mix (1,000+ cc/m) a little to much water could probably cause some misfire. It seem the misfire is happening around the same boost level where the meth/water kicks in. Going to play around with the trigger point and see if it moves the point of missfire around.
Old Nov 24, 2007 | 11:16 AM
LST2's Avatar
That was it. Something when the water/meth injection kicks in. I think there was too much water in the mix. Going to run straight meth and see how it runs.
extremeracer
Engine Management and Tuning
Jun 20, 2013 08:27 AM
s2kkid
Jan 25, 2006 08:17 AM
AJxr
Dec 14, 2005 08:20 PM
b18psi
May 11, 2004 01:06 PM
