Comp ratio???gsr crank-b20 block?
Im puttin a motor together. i have a b20z block and a gsr crank. going turbo with this build so i have also picked up a set of h beam scat rods. the problem im having is choosing pistons. if i go with a set of 9:1 comp pistons wouldnt that put me lower since im using a gsr crank in a b20 block due to losing stroke??
any input would help me...thanks
Re: Comp ratio???gsr crank-b20 block? (AK94GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK94GSR »</TD></TR><TR><TD CLASS="quote">Im puttin a motor together. i have a b20z block and a gsr crank. going turbo with this build so i have also picked up a set of h beam scat rods. the problem im having is choosing pistons. if i go with a set of 9:1 comp pistons wouldnt that put me lower since im using a gsr crank in a b20 block due to losing stroke??
any input would help me...thanks</TD></TR></TABLE>
if you get GSR sized rods and pistons then compression ratio should be in spec for a gsr.
Re: Comp ratio???gsr crank-b20 block? (mike@synapse motorsport)
i plan to order 84.5mm pistons
is there anything i should be lookin for as far as the piston specs themselves other than bore size?
bigsubs
13
05-17-2007 10:30 PM
fuzzynutz
06-30-2004 09:48 AM
