boost b18b or b18c?
Old Oct 24, 2007 | 09:03 PM
94c1v1cex's Avatar
Default boost b18b or b18c?
wanna make about 300 whp as a daily driver. i'm going to use a gsr trans for sure if u do the b18b swap. but which motor will be better for boost? i'm just breaking into b series. i drive a boosted d15b right now. thanks
-Zach
Old Oct 24, 2007 | 09:37 PM
tony413's Avatar
honest answer is
PERSONAL PREFERENCE
Old Oct 25, 2007 | 11:01 AM
Schister66's Avatar
Man U FTW
Id go with a GSR over the LS engine....having the better bottom end and better flowing head is going to be a lot more fun on the street IMO
Old Oct 25, 2007 | 04:00 PM
94c1v1cex's Avatar
Default Re: (Schister66)
same thoughts. i've just heard so much about the ls lovin boost.
Old Oct 25, 2007 | 04:24 PM
AMLS4dr200whp's Avatar
Default Re: (94c1v1cex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex &raquo;</TD></TR><TR><TD CLASS="quote"> same thoughts. i've just heard so much about the ls lovin boost.</TD></TR></TABLE>
yes man so much fun and love the tq, but really depends what kind of power ur looking for as well
Old Oct 25, 2007 | 07:10 PM
blackeg's Avatar
Default Re: (AMLS4dr200whp)
um... heres what ive done over the past 4 years.
turbo'd an ls, made 240whp 200 ftlbs at 10 lbs boost.
turbo'd my friends gsr, made 300/210 at 9 lbs boost.
both setups had the same turbo, t3t4 57 trim. the gsr is incredibly more fun to drive on the street
Old Oct 25, 2007 | 07:21 PM
94c1v1cex's Avatar
Default Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">um... heres what ive done over the past 4 years.
both setups had the same turbo, t3t4 57 trim. the gsr is incredibly more fun to drive on the street</TD></TR></TABLE>
that is the exact setup i wanted to run... t3t4 57 trim garrett on a stock block gsr... but i'm worried about reliability because this will be my dd... can i make 300 whp on a stock block gsr with no problems?
Old Oct 25, 2007 | 09:19 PM
dan89crxsi's Avatar
what about lsvtec
Old Oct 26, 2007 | 02:16 AM
blackeg's Avatar
yeah its reliable, get it tuned well.
i tuned that gsr in about an hour, air fuel was a safe 11.2-11.5:1 and i think it was running 20* timing at 10 psi on the map.
it hits full boost of 8 psi at like 3800 rpm and will creep toward 9ish psi around redline. its a peakboost kit with a full 3" turbo back exhaust no cat
Old Oct 26, 2007 | 08:32 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex &raquo;</TD></TR><TR><TD CLASS="quote">that is the exact setup i wanted to run... t3t4 57 trim garrett on a stock block gsr... but i'm worried about reliability because this will be my dd... can i make 300 whp on a stock block gsr with no problems?</TD></TR></TABLE>
Im using a GT3255b which is a variation of the 57 trim on my daily driver stock internal GSR and ive been at 315/216 for this entire season...i made 275/194 all last season too
So to answer your question, YES you can make 300whp + or - and still have good reliability as a daily....
Old Nov 22, 2007 | 09:12 AM
ktek3's Avatar
boosting an ls at 15 psi 330whp daily driver. no problems at all, guarantee reliability, you just need a good tune. tuning is everything when you boost. if there is one thing that you dont want to cheap out on it is tuning.
Old Nov 22, 2007 | 09:13 AM
ktek3's Avatar
Default Re: (ktek3)
o ya i am running on E85... That helps a lot!
CSP413
Jan 30, 2013 08:38 PM
jdmitr757
Mid-Atlantic (Sales)
Apr 28, 2010 06:08 AM
EKris
Apr 2, 2007 06:17 AM
stock_cx
Nov 10, 2004 08:46 AM
xTeg
Jul 9, 2002 10:44 PM
