smoking catch can?
Old Oct 21, 2007 | 12:40 PM
hotrod99's Avatar
Default smoking catch can?
I just had my b16 built up with GE sleeves,9:1 CP pistons,Eagle rods,acl bearings,supertech valvetrain,Cometic headgasket,ITR water/oil pump.Well i dropped it in the car and started it up for the first time and alittle bit of white smoke is coming out the catch can....is this normal for first start up?
Old Oct 21, 2007 | 02:04 PM
blinx9900's Avatar
Default Re: smoking catch can? (hotrod99)
smoke tends to come from all sorts of places during the first 10 minutes or so, oil is burning off all the parts you installed, rings seating, etc...
Old Oct 21, 2007 | 02:10 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrod99 &raquo;</TD></TR><TR><TD CLASS="quote">I just had my b16 built up with GE sleeves,9:1 CP pistons,Eagle rods,acl bearings,supertech valvetrain,Cometic headgasket,ITR water/oil pump.Well i dropped it in the car and started it up for the first time and alittle bit of white smoke is coming out the catch can....is this normal for first start up?</TD></TR></TABLE>
Your rings are seated yet......and they won't seat until you run your engine correctly...don't just start it up.
Once the rings seat you will still get a little more blowby because not only are you pushing more boost and power, but your pistons and rings are a little looser then stock to allow more heat and power. This looseness also cause extra blowby.
Old Dec 3, 2007 | 10:37 PM
blinx9900's Avatar
Default Re: smoking catch can? (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">
so what is correctly?
Old Dec 4, 2007 | 02:06 AM
Outkast95LS's Avatar
Default Re: smoking catch can? (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">
so what is correctly?</TD></TR></TABLE>
Meaning you have it tuned before you drive it/start it.
Old Dec 4, 2007 | 02:25 AM
DaveF's Avatar
Default Re: smoking catch can? (Outkast95LS)
they all do that, every engine would do it, given the proper system, its nothing to worry about. quit being so damn paranoid and run that pos,.
Old Dec 4, 2007 | 05:15 AM
sp00led's Avatar
Default Re: smoking catch can? (DaveF)
My catch can has steam coming out of it. Not thick smoke but vapor you see evaporating quickly. This is normal in most setups from what i've seen.
Old Dec 4, 2007 | 10:01 AM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast95LS &raquo;</TD></TR><TR><TD CLASS="quote">
Meaning you have it tuned before you drive it/start it.</TD></TR></TABLE>
oh ok, i thought there was some weird thing you had to do first
Anthony2431
Jan 27, 2012 06:24 PM
xlasianizelx
Mar 20, 2008 06:54 AM
EFHATCH88
Dec 29, 2006 01:05 AM
JDM-EJ698
Dec 14, 2005 03:54 PM
MrPotatoeHead
Mar 16, 2005 05:26 AM
