p28 virgin or no??
Old Oct 25, 2007 | 09:44 AM
BoostnEK6206's Avatar
Default p28 virgin or no??
i currently have a chipped p28 ecu running in my car n/a and am going to be boosting and i am wondering if i should get a virgin ecu for the hondata or if i can jus use the one i have now which has already been socketed and chipped? thanks for the help
Old Oct 26, 2007 | 10:10 AM
Default Re: p28 virgin or no?? (BoostnEK6206)
bump
Old Oct 26, 2007 | 10:47 AM
vtecdelly's Avatar
what hondata? an s300 will need to have the 28 pin chip bed changed but the others should be ok. other than the 4 pin comunication port
Modified by vtecdelly at 4:50 PM 10/28/2007
Old Oct 26, 2007 | 09:54 PM
mtber's Avatar
You should be able to use the ecu you have now
If you are switching to s300, you may want to have the installer look at the condition of your ecu's traces first to ensure he can install the new style pins for s300 etc..
Old Oct 27, 2007 | 02:45 PM
Default Re: p28 virgin or no?? (mtber)
im gonna be using s300 with the boost contoler also
Old Oct 27, 2007 | 10:49 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostnEK6206 &raquo;</TD></TR><TR><TD CLASS="quote">im gonna be using s300 with the boost contoler also</TD></TR></TABLE>
Shouldn't be an issue. Simply have the needed hardware added to the ecu at the time of s300 installation
Old Oct 29, 2007 | 10:32 AM
bump ^^^^
poormans_typer69
Feb 16, 2008 08:56 AM
pacey
19
Nov 10, 2007 06:56 PM
VDoP-B18C1
Jul 12, 2004 03:55 PM
MADEINIRAQ
May 5, 2004 09:52 PM
