fuel line sizing???
Old Oct 22, 2007 | 04:31 PM
got wide's Avatar
Default fuel line sizing???
ok im right in the middle of building my first race engine/car and have a question on fueling.
my goal is around 750 whp my set up is as follows:
95 ls with gsr swap
block was built with 84mm darton mid's
ls crank and ls length manley turbo tuff rods
je 9:1 coated pistons
arp studs (head, main & rod)
calico coated bearings etc.
i will be doing the head work this winter but am currently thinking about going with s2 pro 2 valve train and just ordered a garrett gt4094r today (wallets feelin kinda light lately)
but as far as the fuel im a little confused as to where to go next. i currently have a str 3/4in fuel rail with an AEM regulator and a walbro 255 pump and the rest of the system is stock. i know i need to go with larger lines but what kind (hard line or braided) and what sizes do i need for feed and return, also what size fittings? i know the rail is taped for -an fittings but what do i need to connect the lines to the tank?
also what size injectors do i need? i was thinking about getting the edelbrock IM with the secondary ports on the bottom. would it be better to run a single set of injectors or run secondaries so i only need the big injectors for high boost (i forgot to mention i have an AEM ems). and what kind of injectors is better for this setup(hi or low imp.)
im really scared about leaning out (p.s. im running a small shot of nitrous to spool ) and want to do the fuel system the best that i can. i know its a lot of questions but any help i can get i appreciate
Old Oct 23, 2007 | 08:19 AM
got wide's Avatar
bump
Old Oct 23, 2007 | 08:34 AM
Boner_Ben's Avatar
Default Re: (got wide)
I'm using 2 Bosch 044 pumps, -6 lines to each pump and then -6 from each pump to a Y block and -10 from there to the rail. -6 Return. Is it a street car? 1600's dont idle the best but honestly unless its your commuter car then who cares.
Old Oct 30, 2007 | 02:45 PM
got wide's Avatar
Default Re: (Boner_Ben)
yeah it will probably see more street time than track but not a daily driver so im not too woried about idle as long as its not too ridiculous.
do i really need two pumps? and arent 1600's a little too big even if i only run one set of injectors??
dantamparacer
Aug 21, 2011 05:18 PM
Pandahatch
Jan 28, 2008 10:05 AM
Green Lude 93
Aug 9, 2005 06:04 PM
Tegra
Jan 4, 2003 08:51 PM
justinCO
Jun 7, 2002 08:55 PM
