Quick A/f wire question
It's the solid white wire coming from the O2. I just run a wire from the bulkhead to that point, as when I use my WB02, I hook the narrowband output on the wire and plug it into the narrowband plug so I can remove if required easily.
If you look for an OBDI pinout, it will show you where on the ECU side to hook it up.
wickedxboi
Mar 10, 2003 05:37 PM
