Final Tial Question :)
Old Oct 20, 2007 | 04:28 PM
Dunc's Avatar
BCICAN
Default Final Tial Question :)
I dunno why I thought to try this. Since I think I am outflowing my current 38 I decided to see how far the 44's valve would open. Is this normal? Wouldn't it be better if the valve opened all the way to allow even more flow? Thanks again guys.
Old Oct 20, 2007 | 06:39 PM
R@mon's Avatar
Default Re: Final Tial Question :) (Dunc)
im pretty sure the valve open that much is already flowing as much as a 44mm hole is going to flow.
Old Oct 20, 2007 | 06:44 PM
BoostedJeff's Avatar
Well, the valve doesn't even open that much during normal operation. As it appears, you took this picture without a spring in it.
Old Oct 20, 2007 | 07:02 PM
Dunc's Avatar
BCICAN
Default Re: Final Tial Question :) (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">Well, the valve doesn't even open that much during normal operation. As it appears, you took this picture without a spring in it.</TD></TR></TABLE>
Correct. I had the top of it off just to verify that the spring was in fact the stated spring on the box. I just pushed it open with my finger to see the maximum it would open. When it is open that far the metal octagon shaped top of the inside diaphram is touching the top outer casing.
gonmaro
Sep 21, 2008 03:21 PM
swatteamtimmah
May 16, 2006 11:13 PM
Si Shane
37
Jun 22, 2005 02:42 PM
Screamer
Dec 17, 2003 04:41 PM
