Calculating effective compression ratios
Old Oct 26, 2007 | 05:06 PM
EJ8 GSR-T's Avatar
Default Calculating effective compression ratios
Does anyone know of an equation to predict compression rations at certain boost settings? ie with initial CR of 9:1 with oh 17psi....im sure somehow the bore and stroke come into play...any ideas?
Old Oct 28, 2007 | 05:35 PM
EJ8 GSR-T's Avatar
Default Re: Calculating effective compression ratios (EJ8 GSR-T)
Man anytime i post a pic of my car or something i get a million and one dumb comments, but when its a logical question...noone has anything h-t
Old Oct 29, 2007 | 04:04 PM
NJIN BUILDR's Avatar
It's not a very help full number.Relating boost pressure to compression ratio is apples and oranges.PSI of boost is backpressure in the manifold not pressure in the combustion chamber.Cylinder pressure is the real psi number of importance.
Old Oct 30, 2007 | 10:56 AM
TheShodan's Avatar
Moderator
Default Re: Calculating effective compression ratios (NJIN BUILDR)
I think he is referring to changes in effective compression.
Old Oct 30, 2007 | 11:58 AM
Ramma's Avatar
Default Re: Calculating effective compression ratios (TheShodan)
I believe its like 20-1. Ask a machine shop. there is a chart with motor size and boost that give the compression.
Old Oct 30, 2007 | 11:30 PM
EJ8 GSR-T's Avatar
Default Re: Calculating effective compression ratios (Ramma)
dont really have any shops to ask. There should be some sort of equation relating the chamber size, original cr, and stroke....i just haven't got a clue how to compile an equation.... :-/
And yeah im going for effective CR...for fuel calculations.
capmcatastrophy
Jun 2, 2010 07:06 PM
TehMoonRulz
May 16, 2005 01:15 PM
Ragezero76
May 15, 2002 04:17 PM
Feuerraeder
Feb 23, 2002 09:11 PM
