GTR Turbo water lines
is it true that it is not neccesary to run the water lines on the garret ball bearing turbo's, and that if you do, it will significantly raise the coolant temp in your car and maybe cause the car to overheat??
Re: GTR Turbo water lines (187Chor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 187Chor »</TD></TR><TR><TD CLASS="quote">is it true that it is not neccesary to run the water lines on the garret ball bearing turbo's, and that if you do, it will significantly raise the coolant temp in your car and maybe cause the car to overheat??
...... who told you this information?
Re: GTR Turbo water lines (Urban_Indian)
you dont HAVE to run the lines. full race doesnt use them either. some people do have problems with the coolant lines connected
Modified by D@nnY at 9:02 AM 10/27/2007
Moderator
Re: GTR Turbo water lines (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">you dont have to run the lines. full race doesnt use them either. some people do have problems with the coolant lines connected</TD></TR></TABLE>
They can also replace their turbos on a regular basis because they have hundreds in stock.
save yourself, and save your turbo, GTR turbos need to use their water lines to be efficient and have a long life..
I cant imagine a turbo boiling the coolant, unless possibly on a racetrack on a hot day, but if the cooling system is up to par there shouldnt be a problem, and if you dont run the lines you void the Turbo Warranty
Re: (96 GSR-T)
My engine coolant temps didn't change with the water lines connected to my GT30R.. It will allow the turbo to live a longer life, and will keep the warranty intact.
im already running a dual core half width aluminium rad with slim fan but the mechanic says i will need most likely need a full width rad :S
Moderator
Re: (187Chor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 187Chor »</TD></TR><TR><TD CLASS="quote">im already running a dual core half width aluminium rad with slim fan but the mechanic says i will need most likely need a full width rad :S</TD></TR></TABLE>
Only depending upon the purpose of the car. If it's mainly for street use, you should be fine.
Re: (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash »</TD></TR><TR><TD CLASS="quote">My engine coolant temps didn't change with the water lines connected to my GT30R.. It will allow the turbo to live a longer life, and will keep the warranty intact.</TD></TR></TABLE> how did you run your lines?
Man U FTW
Re: (ctr83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctr83 »</TD></TR><TR><TD CLASS="quote"> how did you run your lines?</TD></TR></TABLE>
I'm glad you searched, but next time rather than bringing back a thread from October, just start a new one and reference the old thread.
