Single Cam Turbo Build
* B A N N E D *
im starting to put together motor parts for my single cam turbo setup, i was planning on usisn a z6 block, with a vtec head, vitara pistons, and eagle rods, and run about 10lbs
i got a deal on a y8 head with crower valve traing, fresh rebuild
but i heard that the clearneces of the vitara pistons in a z6 block will interfere with something on a y8 head
should i get a y8 block as well? i heard z6 was best for boost
Re: Single Cam Turbo Build (nicko360)
o snap dog....thats the same set up i got.....im actually getting my crankshaft back on wednesday at the latest......but yea we'll see who finishes first.....good luck with your build......
Re: Single Cam Turbo Build (lakahang)
goodluck with build
They say the z6 is better for boost because the y8 oil pump sucks and has been known to spin bearings. But there are tricks from theoldone.com to boost the pressure coming from the oilpump.
I would say stay away from the Y8 head. It creates the infamous high advance, and cam timing woes.
The Z6 flows better.
I don't know about a clearance issue with vitaras on a 1.6L block, considering that the pistons sit about 2-3MM below the deck, not to mention the huge dish in the piston as well. If you feel in doubt, put the head on snug with an old MLS HG and clay it, you will find good results in your low C/R motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 »</TD></TR><TR><TD CLASS="quote">
should i get a y8 block as well? i heard z6 was best for boost</TD></TR></TABLE>
There is no clearance problem. Build your Z6 bottom with the Y8 head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaredKaragen »</TD></TR><TR><TD CLASS="quote">I would say stay away from the Y8 head. It creates the infamous high advance, and cam timing woes.
Y8 head is fine. In a stock Y8 block the interaction between the piston crown and the heads quench pad design necessitate the oddball igntion timing. On a build like this with the mega-dished Vitara pistons, the quench pad area is no longer existent.
i ♥ snails
yeah the piston has to match the had for it to be a true "quench pad". just from observation the z6 seems to deal with high cylinder pressures better than the y8 in terms of timing and the tuning window. I see alot more y8 headlifting issues which is caused by detonation but it does happen on z6's. just my thoughts
* B A N N E D *
Re: Single Cam Turbo Build (JFK78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JFK78 »</TD></TR><TR><TD CLASS="quote">
what was your 400 hp vitara setup?
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JFK78 »</TD></TR><TR><TD CLASS="quote">It's a full Y8, stock port head. </TD></TR></TABLE>
maybe ill hit you guys up, im somewhat local
