Duel Rad setup
Old Oct 22, 2007 | 10:12 AM
powerdbygarrett's Avatar
Default Duel Rad setup
has anyone ever tried to run two seperate radiators? my setup is one of the ones that doesnt allow a full 3inch rad. so im using a civic half rad. now i wanted to know if i got another stock civic half rad and just tapped the hoses top to top bottom to bottom and the overflow will that work? will it cool any better? just curious to know if i would benifit from something like this. thanks
Old Oct 22, 2007 | 11:41 AM
k24em2's Avatar
Default Re: Duel Rad setup (powerdbygarrett)
Will it work, in theory yes. Better? maybe. More complicated, definitely.
Old Oct 22, 2007 | 12:03 PM
y more complicated? all you would really have to do is mount the second rad. the bottom and top hose going to the motor from the first rad cut them in the apporpriate place. run two more hoses from the new rad, and tee them in!
I just dont want to be the one who tries it out. wondering if anyone did this before
Old Oct 22, 2007 | 12:09 PM
rmcdaniels's Avatar
Default Re: Duel Rad setup (k24em2)
They will fit, I used two in my EM1 and in my EG hatch:
The second one on my setup was for the air/water intercooler, but I guess that you could just daisy-chain them for more cooling.
Old Oct 22, 2007 | 12:36 PM
well i wouldnt be using a second aftermarket thicker one. cause if that was the case i would be able to use my full rad that i bought. but thats my problem it wont fit grrr stupid manifold.
the second one would be a stock size half rad
Old Oct 22, 2007 | 03:46 PM
rmcdaniels's Avatar
Default Re: (powerdbygarrett)
Use whatever radiator you want, I was just showing that two half-width radiators fit easily.
Old Oct 23, 2007 | 12:25 AM
SwappedTURBOegg's Avatar
i have a question for you.
why?
Old Oct 23, 2007 | 07:04 AM
cause i cant fit a full rad
Old Oct 23, 2007 | 07:39 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerdbygarrett &raquo;</TD></TR><TR><TD CLASS="quote">cause i cant fit a full rad</TD></TR></TABLE>
Then where are you planning on putting the second radiator?
Old Oct 23, 2007 | 08:12 AM
Default Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">
Then where are you planning on putting the second radiator?</TD></TR></TABLE>
same place a full rad would go. i just cant fit a full aftermarket thicker rad cause of the turbo. so i run a 2.5inch half rad but where the full rad wouldnt fit infront of the turbo i can place a stock thin half rad
Old Oct 23, 2007 | 06:29 PM
NJIN BUILDR's Avatar
Custom radiators can be made with cores and tanks just like intercoolers.And there is no reason that two radiators can't be used as long as you can bleed them.
Old Oct 23, 2007 | 07:26 PM
yea i tried a custom rad, they wanted 800+
Old Oct 24, 2007 | 02:22 AM
SD_Lurker's Avatar
HT White Ops
Why would you want to do this? Are you having overheating issues??
Old Oct 24, 2007 | 05:05 AM
SOHCD16y8's Avatar
Yes it will work fine.
Everyone needs to back off, if he wants to do it let him do it.
Old Oct 24, 2007 | 05:22 AM
Adi Radoncic's Avatar
On Fire!
Default Re: (SOHCD16y8)
My question is how do I get 3 to fit??
Old Oct 24, 2007 | 05:24 AM
lol why still. over heat or because you read it on H-T that you MAY need it
Old Oct 24, 2007 | 08:14 AM
i wouldnt do it for ***** and giggles. before my build i would heavly overheat in trafic but from what i found out after dissasembling the motor was that my hg was cracked in a couple places. so it might have been due to that. but now with my new build i havent drove the car yet so i dont know if it will over heat.
im not saying i want to do this, i just wanted to know if it was possible to do just in case i would still be over heating and i thought that might help. and would be better then spending 800+ on a custom radiator.
and i know its going to fit
my original question was if it would be more efficiant? not would it fit. just if it would work
Old Oct 24, 2007 | 08:19 AM
EJ1 wilcox's Avatar
Couldn't you just get a full sized single core radiator?
Old Oct 24, 2007 | 08:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">Couldn't you just get a full sized single core radiator?</TD></TR></TABLE>
yeah i could, but i got my civic duel core for free and i can get the single core civic half rad for free
Old Oct 24, 2007 | 02:35 PM
2point2's Avatar
never knew philly was so close to the equater..
Old Oct 24, 2007 | 02:42 PM
in the summer its right under the sun :-)
Old Oct 24, 2007 | 03:23 PM
92gs-r's Avatar
why don't you use one integra radiator? I'm assuming the thickness is whats preventing you from using an aftermarket full length rad. If that doesn't work take a tape measure and go down to pasyunk ave. and do some shopping. 2 rads look rigged.
eggie75
Jul 18, 2012 09:33 AM
pcguy760
Aug 13, 2008 11:21 AM
T25 civic
Mar 19, 2007 06:12 PM
Suzukii
Nov 27, 2006 09:40 AM
Sohc Driver
Dec 5, 2004 05:40 PM
