wideband o2 placement
Old Oct 19, 2007 | 08:51 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Default wideband o2 placement
just want to know if i run my o2 to close to the turbo if i will have any issues like not reading properly or burning out the o2's fast.. here is a pic of what my down pipe looks like http://www.atpturbo.com/Mercha...e=MDP
im going to use the one on the top of the bend if i can. or i can just put a new one in down at the bottom back side of the motor if this is going to cause me problems
Old Oct 19, 2007 | 09:31 PM
xenocron's Avatar
Default Re: wideband o2 placement (1QwIkEf)
8 - 18" from the exhaust outlet on the turbo
Old Oct 20, 2007 | 07:40 AM
b16a4's Avatar
Default Re: wideband o2 placement (xenocron)
my aem said furtherest away is the best
Old Oct 20, 2007 | 09:36 AM
mike93eh2's Avatar
PLX says 24" from turbo is ideal..
you dont want it that close like in the picture.
Old Oct 20, 2007 | 11:45 AM
tony413's Avatar
12-18 inches and get a NTK sensor if you dont have one.
Old Oct 20, 2007 | 12:19 PM
DRAGLS's Avatar
Default Re: (tony413)
I have mine 6" from the turbo, it would overheat the sensor and it would shut down.
Ended up heat wrapping the down pipe and using the innovate heat sink, I haven't had a problem since.
Old Oct 20, 2007 | 09:00 PM
1QwIkEf's Avatar
Default Re: (DRAGLS)
631 Teggy
Sep 12, 2006 05:44 PM
the.hamburglar
Jun 12, 2005 03:47 PM
TurboJesse
Sep 28, 2003 02:55 PM
EU BATT
Nov 21, 2002 02:48 PM
MIKES
Jun 18, 2002 02:58 PM
