NEED HELP WITH MINI ME
Old Oct 25, 2007 | 01:39 PM
omahacrx's Avatar
Default NEED HELP WITH MINI ME
I have a 91 crx I am planning on doing a mini me swap. Which should bring my compression to 10.1:1. I was going to get a apexi controller for the vtec and fuel management. Because I also wanted to turbo the engine installing a block guard while I had the head off. what should i get for horsepower and is this even possible? Has anyone tried it? I have a d15b2 block and the older (I think d16z7) head. Any other suggestions?
Old Oct 25, 2007 | 01:43 PM
nonvtecD's Avatar
If you're going turbo don't waste your time on the mini-me, blockguards are stupid anyway when your rods are going to go long before your sleeves. How do you have a b2 block and not a b2 head? If you're DPFI you should swap to MPFI before you boost so you have some decent ecu control and what not.
Old Oct 25, 2007 | 04:41 PM
omahacrx's Avatar
Right now it is a stock d15b2 engine but I have the vtec head. I was planning to turbo it after putting it together if it was to slow. I whant to build this car for scca.
mikewhomiko
Aug 18, 2016 12:58 AM
meece0927
21
Apr 1, 2013 10:52 AM
illogic65
Dec 12, 2004 04:30 PM
