timing sound rite?
Old Oct 19, 2007 | 01:53 PM
turbo boost's Avatar
Default timing sound rite?
i cracked a sleeve on my lsvtec and was wondering y....it was tuned by a good tuner....maybe to much timing?...it had 20.25degrees at 8k..to much im just wondering?
Old Oct 19, 2007 | 01:55 PM
xenocron's Avatar
Default Re: timing sound rite? (turbo boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo boost &raquo;</TD></TR><TR><TD CLASS="quote">i cracked a sleeve on my lsvtec and was wondering y....it was tuned by a good tuner....maybe to much timing?...it had 20.25degrees at 8k..to much im just wondering?</TD></TR></TABLE>
3 lbs of boost or 80 psi?
What turbo? What motor? What EMS?
Old Oct 19, 2007 | 02:00 PM
Default Re: timing sound rite? (xenocron)
o sry i forgot to put that....13psi..crome......lsvtec\t3t04b v trim made 285whp...flat 11a/f
Old Oct 19, 2007 | 02:07 PM
xenocron's Avatar
I would say thats a little high...
You really need to worry more about what the timing is at at peak torque for the motor/setup, not redline...and if its detonating or not (hopefully).
Whats the timing at 5800 rpms?
Old Oct 19, 2007 | 02:15 PM
at 5800 its 19.25degrees
Old Oct 19, 2007 | 02:24 PM
im gona tune it my self next time...can u give me some tips on tuning the timing on a boosted honda...what to set the retard per pound of boost....whats the lowest/safest to go on that with an lsvtec?..any info would be awsome thanks
Old Oct 19, 2007 | 05:50 PM
b16a4's Avatar
bump for info
Old Oct 19, 2007 | 09:34 PM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo boost &raquo;</TD></TR><TR><TD CLASS="quote">im gona tune it my self next time...can u give me some tips on tuning the timing on a boosted honda...what to set the retard per pound of boost....whats the lowest/safest to go on that with an lsvtec?..any info would be awsome thanks</TD></TR></TABLE>
Get it on a dyno...start conservative and add timing slowly while always pulling plugs.
Do a lot of reading and research too. Have the right tools for the job...
There are many more...but I dont have time to work on my book tonight
Old Oct 20, 2007 | 05:08 AM
blackeg's Avatar
i was running around 13* at 6000 and about 17 at 8000, never had issues. im sure it could have made more power, but i opted to be safer.
what gas were you running out of my curiosity
Old Oct 20, 2007 | 05:13 AM
b16a4's Avatar
Default Re: timing sound rite? (blackeg)
the higher the rpm goes, the timing should advance?
Old Oct 20, 2007 | 08:09 AM
Default Re: timing sound rite? (b16a4)
we have 91 octane here..
xenocron u say add timing slowly,do u mean add it in the retard per pound of boost...or in the cells it self?
Old Oct 20, 2007 | 08:18 AM
SOHC_MShue's Avatar
yea sounds like too much timing
Old Oct 20, 2007 | 08:56 AM
b16a4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo boost &raquo;</TD></TR><TR><TD CLASS="quote">we have 91 octane here..
Old Oct 20, 2007 | 11:26 AM
bump??
Old Oct 20, 2007 | 12:52 PM
omniscient's Avatar
Default Re: timing sound rite? (SOHC_MShue)
I set it to 1* of retard per pound of boost. Make sure everything's straight then go by the cells. It's tedious without a dnyo. I don't mess with timing much, basically just get everything to flow well.
Old Oct 20, 2007 | 09:21 PM
Default Re: timing sound rite? (omniscient)
okie
Old Oct 24, 2007 | 10:44 AM
xenocron's Avatar
Generally I set it at a standard linear retard and keep the fuel in line. I try different linear and stepped retard settings first and then fine tune from there once reasonably close.
Unfortunately its hard to make proper timing changes without a dyno.
T9U4ReBgO
Feb 4, 2008 04:13 PM
asianspeed
Dec 4, 2007 07:01 PM
The Jacko
Jun 22, 2005 12:07 PM
CRXdan
Dec 20, 2004 10:23 AM
bmm89
Nov 21, 2004 08:17 PM
