400hp lsT
Old Oct 26, 2007 | 06:19 PM
T9U4ReBgO's Avatar
Default 400hp lsT
im building a strait ls and wanting for 400hp+ and im doing it on a budget....right now i have a built bottom end with eagle rods and 8.8:1 srp i think pistons...wanting to put crowler 404s in it....do u think i should upgrade the springs and retainers...what size turbo should i use for this kinda power goal...and do u think this power goal is possible with what i got and wanting to get....keep in mind im doing this on a budget too...thanks for the input guys...
Old Oct 26, 2007 | 06:21 PM
kyden's Avatar
Default Re: 400hp lsT (T9U4ReBgO)
springs and retainers are a MUST for those cams!
Old Oct 26, 2007 | 06:29 PM
T9U4ReBgO's Avatar
Default Re: 400hp lsT (kyden)
yea i thought that but alot of ppl just say they put 404s with a good intake manifold and they are making good power...thanks for the input bro ill keep that in mind...
Old Oct 26, 2007 | 08:35 PM
T9U4ReBgO's Avatar
bump
Old Oct 26, 2007 | 08:37 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
um you CAN'T just put those cams in without the springs/retainers... it won't work.. you'll mess your **** up
and i used a SC6152e to make 403whp on 18-19psi on my built ls motor
and its CROWER , not crowler
Old Oct 26, 2007 | 09:24 PM
T9U4ReBgO's Avatar
Default Re: (tannerLSt)
ok my bad ha i suck at spelling and do u really think its worth it to go with the crower setup?
Old Oct 26, 2007 | 09:40 PM
Bugermass's Avatar
Default Re: (T9U4ReBgO)
I made 407 on a customers stock LS motor with a SC61, topmount mani, some regrind all motor cams, and 1000CC injectors on pump gas. @ 24PSI been running for about 4-5 months now, and its still being ragged on daily..
Old Oct 26, 2007 | 09:45 PM
alpha's Avatar
The Crower 404's will work great with a good exhaust manifold and intake manifold
Old Oct 26, 2007 | 11:22 PM
T9U4ReBgO's Avatar
Default Re: 400hp lsT (alpha)
i was told to run the stage 2 crower turbo cams that i would like the results better than the 404s....any suggestions on that...
Old Oct 27, 2007 | 02:47 AM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T9U4ReBgO &raquo;</TD></TR><TR><TD CLASS="quote">i was told to run the stage 2 crower turbo cams that i would like the results better than the 404s....any suggestions on that...</TD></TR></TABLE>
Whats your budget?
Cams, valvetrain...LS, 400 hp and Budget usually dont work well together.
Old Oct 27, 2007 | 05:56 AM
DRAGLS's Avatar
Go with the crane turbo cams or the crower 403's or 404's.
I personaly run the crower 404's with a 60-1 p-trim in a .82 a/r housing.
Old Oct 27, 2007 | 06:03 AM
blackeg's Avatar
Default Re: 400hp lsT (DRAGLS)
upgrade those springs and retainers!!
also get an aftermarket intake manifold. your torque curve will thank you
Old Oct 27, 2007 | 06:07 AM
DRAGLS's Avatar
Default Re: 400hp lsT (blackeg)
I forgot to mention that I also run the crower spring & retainers with a skunk manifold with a 8400 rpm shift point.
daigo
Dec 29, 2013 09:31 AM
zex_cool
Oct 20, 2009 12:19 PM
smoovy
Jun 21, 2007 07:38 PM
Globe1280
Apr 20, 2006 05:23 PM
RICEBURNER1406
Mar 3, 2002 02:08 PM
