help please
Old Oct 20, 2007 | 12:00 AM
jdmray's Avatar
Default help please
ok so i used to have a turbo gsr swap in a 92 coupe. i parted out the car but kept the whole swap because it ran perfect no problems or cel. it is tuned on crome. the motor is all stock dsm injectors. well now i put the swap in my new car and for some reason it will run and idle. but when you give it gas it cuts out and dies. it was throwing three codes 7,14, and 21. changed out the throttle body and got rid of code 7. code 14 doesnt show up untill the car is started. also ive never really seen this on an obd1 car but the map sensor is on the fire wall so the throttle body is an obdo one i believe because it only has one sensor on the side of it. i dont know whats up any help would be great.
Old Oct 20, 2007 | 04:37 AM
DaveF's Avatar
Default Re: help please (jdmray)
maybe you mix up the tps/map connectors.
Old Oct 20, 2007 | 08:27 AM
jdmray's Avatar
Default Re: help please (DaveF)
tried that already thanks for the help
Old Oct 20, 2007 | 10:23 AM
DaveF's Avatar
which map sensor do you have hooked up ? do they both have a vacum source to the intake manifold ?
code 14 is idle air control valve <-- if this isnt hooked up the car will barely idle, if at all.
code 21 is vtec sol.
retrace your wiring back to the ecu.
jdmray
Oct 23, 2007 11:59 AM
93sidelsolvtec
Jan 28, 2007 11:58 AM
weaslehunter1
Jul 1, 2005 10:27 PM
Achenar
Oct 2, 2004 01:45 PM
