How much on a B16??
Old Oct 21, 2007 | 03:32 PM
hmongxcuz's Avatar
Default How much on a B16??
I have a GT28R turbo on my B16. Anyone know how much lbs of boost does it need to be at to get 340whp??? Pretty much maxing out the turbo.
Old Nov 26, 2007 | 04:03 PM
Robert Padron's Avatar
Default Re: How much on a B16?? (hmongxcuz)
At 300+ hp that stock block won't even last you a month with the safest tune posible. Keep it 250-275hp so it will last you a long while.
Old Nov 26, 2007 | 04:32 PM
hmongxcuz's Avatar
Default Re: How much on a B16?? (Robert Padron)
i just leave at 9psi now 267whp
Old Nov 26, 2007 | 04:55 PM
SovXietday's Avatar
340whp 20-25 probably. Couldn't tell you exactly but plan on pushing the turbo deep into it's efficiency range.
Old Nov 26, 2007 | 07:17 PM
FactionR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robert Padron &raquo;</TD></TR><TR><TD CLASS="quote">At 300+ hp that stock block won't even last you a month with the safest tune posible. Keep it 250-275hp so it will last you a long while.</TD></TR></TABLE>
that turbo is maxed at 300whp. get another turbo.
Old Nov 26, 2007 | 11:22 PM
187Chor's Avatar
push it another 2psi it should bring u just under 300 and ull still be safe..
im doing a lil less than 300 on my stock b16 and its been over 1000km now and 3 weeks.. (i know thats not too long but i think with a good tune it will last)
Old Nov 27, 2007 | 12:15 AM
quicksilver1689's Avatar
i ♥ snails
will you tune my motor?
Old Nov 27, 2007 | 06:23 AM
morgan@synapse motorsport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robert Padron &raquo;</TD></TR><TR><TD CLASS="quote">At 300+ hp that stock block won't even last you a month with the safest tune posible. Keep it 250-275hp so it will last you a long while.</TD></TR></TABLE>??
weve got cars running around for years at 300+ is there a timer your ecus that say blow up block now?
to the op go to the dyno and turn up the boost see what it makes, every dyno reads different there is no magic numbers that says 340whp. doubt the turbo can make that though.
Old Nov 27, 2007 | 06:57 AM
Schister66's Avatar
Man U FTW
Thanks for your "opinion," too bad you're wrong...check my sig. I've been ~300whp for 2 years and still no problems....there are countless others too
Old Nov 27, 2007 | 07:13 AM
Specail Ed's Avatar
Default Re: How much on a B16?? (mike@synapse motorsport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport &raquo;</TD></TR><TR><TD CLASS="quote">??
Lol, yeah, it's called the Chuck Norris tune!!!
Old Nov 27, 2007 | 08:30 AM
bzyq2001's Avatar
can i rev b16a2 to 10k rpm with my holset hy35 - i will have balance crank, forged pisons, eagle rods and block guard (stock slaves) and built haed
Old Nov 27, 2007 | 08:39 AM
top end tuner's Avatar
Default Re: How much on a B16?? (Specail Ed)
thats not true im at 300whp and have 145,000 miles on the car(b16a2) well say it and sait over again but people wont listen so her it goes ITS ALL IN THE TUNE
Old Nov 27, 2007 | 09:08 AM
hmongxcuz's Avatar
well now i know that the turbo cant make more than 310WHP, i was planning to tune it at 14PSI but im gon tune it at 12PSI just to get right under 300WHP, the turbo will max out probaly around 16PSI i say
haha all the turbo b16's drivers come out
Old Nov 27, 2007 | 09:09 AM
hmongxcuz's Avatar
Default Re: (187Chor)
WHAT TURBO YOU RUNNING?
Old Nov 27, 2007 | 09:10 AM
hmongxcuz's Avatar
Default Re: How much on a B16?? (top end tuner)
Old Nov 27, 2007 | 05:48 PM
187Chor's Avatar
Default Re: (hmongxcuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongxcuz &raquo;</TD></TR><TR><TD CLASS="quote">WHAT TURBO YOU RUNNING?</TD></TR></TABLE>
i have a GT3082R
why dont u sell ur turbo and get the GT2876R that way u can have the 340 u want and some room for a little more if u get bored
Old Nov 27, 2007 | 06:02 PM
hmongxcuz's Avatar
i might just go with the t3/t4 57 trim
man you made mad power with just 8PSI
Old Nov 27, 2007 | 06:05 PM
Schister66's Avatar
Man U FTW
i'm running a GT3255b on my GSR and making good power IMO...i like it. It spools fine and makes good power all around.
Old Nov 27, 2007 | 06:23 PM
Default Re: (Schister66)
im running a t3/to4e 60 trim .63 ar
Old Nov 27, 2007 | 06:31 PM
hmongxcuz's Avatar
i think its good power too
IMO if you can make 300WHP or over on 10PSI it is GOOOD
Old Nov 27, 2007 | 06:32 PM
hmongxcuz's Avatar
Default Re: (top end tuner)
good set-up, im about do a similar too
Old Nov 28, 2007 | 12:56 AM
blinx9900's Avatar
to the op go to the dyno and turn up the boost see what it makes, every dyno reads different there is no magic numbers that says 340whp. doubt the turbo can make that though.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks for your "opinion," too bad you're wrong...check my sig. I've been ~300whp for 2 years and still no problems....there are countless others too</TD></TR></TABLE>
im not defending the guy but perhaps he meant that 300whp on that turbo might be risky becuase its so small and would be pretty maxed out and be pushing A LOT of hot air which = high iat's which can be problematic? just a thought, im with you guys 317whp here no problem stock internals...
1sikhatch
Jan 19, 2012 03:44 PM
Sniper*oK
27
Nov 4, 2005 05:18 PM
sleeperHatch
May 20, 2005 06:28 PM
Rocks
Feb 1, 2005 02:54 PM
89efhatchy
Sep 2, 2004 12:58 PM
