need ro put a new head gasket fel pro any good ?
need to put a new head gasket on , fel pro any good ?
the setup is a ls turbo t3t4 on 9lbs i reused the stock head studs and blew the head gasket will a felpro headgasket work good with arp head studs any info is appreciated thanks guys
felpro is the exact same as the oem honda gasket and cheaper. made in same factory.
im running one here with 400whp for a long time now with no problems.
/thread
/thread
Moderator
Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 »</TD></TR><TR><TD CLASS="quote">felpro is the exact same as the oem honda gasket and cheaper. made in same factory.
/thread</TD></TR></TABLE>
Huh? Can you explain that please? I went to Tochigi Japan where they made the OEM gaskets for honda. Felpro may be the same specifications, but they're not the same.
Use Felpro if you wish, I personally like OEM.
Re: need to put a new head gasket on , fel pro any good ? (SOHC_MShue)
There's nothing wrong with Felpro. looking at the 2 side by side, they are the same. the only thing I can could see that was different was the black on the bottom and Felpro had no numbers on the distributor side. both work well. OEm is OEM, but in this case, Felpro works great too. use at your discresion.
Re: (thatblkguy)
k i got this for head sequence
8, 4, 2, 6, 10
7, 3, 1, 5, 9
and this for cam caps
13, 9, 5, 1, 3, 7, 11 (side of cam cover closest to intake)
14, 10, 6, 2, 4, 8, 12 (side of cam cover closest to exhaust)
Shown above is one cam cover, sequence is the same for intake and exhaust cam cover.
#1-10 20ft-lbs (240in-lbs) #11-14 7.2ft-lbs (86in-lbs) (94+ B18C specs)
#1-10 16ft-lbs (192in-lbs) #11-14 8ft-lbs (96in-lbs) (B16A specs)
are these correct
8, 4, 2, 6, 10
7, 3, 1, 5, 9
are these correct
Freshdot
09-20-2010 10:41 AM
Joeski99Si
04-22-2009 09:57 PM
