whos running a borg warner s352
Old Aug 23, 2008 | 09:24 AM
flatblackhatch's Avatar
Default whos running a borg warner s360
Modified by flatblackhatch at 10:51 AM 8/23/2008
Old Aug 23, 2008 | 09:30 AM
tony413's Avatar
ummm s352 ? is that a new one or do you mean the s362 cause thats a bad *** street turbo
Old Aug 23, 2008 | 09:37 AM
Default Re: (flatblackhatch)
has a 62mm inducer and is rated at 65lbs/min
Old Aug 23, 2008 | 09:52 AM
any one using on t3 b16 with topmount or let me know how its working for you
Old Aug 23, 2008 | 10:08 AM
tony413's Avatar
you just edited your first post to nothing and your title still is not all that correct. are you asking about the S362 or not ?
Old Aug 25, 2008 | 09:10 AM
Default Re: (tony413)
yes 362 my bad
Old Aug 25, 2008 | 09:32 AM
tony413's Avatar
its a kick *** turbo goto bullseyepower.com and check it out. what exactly did you want to know about it
Old Aug 26, 2008 | 08:00 AM
just what times people are running on a b16 where running full interior 00 si and im just curious
Old Aug 26, 2008 | 08:52 AM
tony413's Avatar
i havent seen the turbo perform on any 1.6L sad to say, so im not to sure how it will fair out. if you want a bw turbo for your b16 look at the s256 and s258
Old Aug 26, 2008 | 04:57 PM
we already bought it and shodan recomended it to us just havent got it on the dyno yeat but when we do ill post are numbers
Old Aug 26, 2008 | 05:53 PM
tony413's Avatar
sweet whats your goal
Old Aug 27, 2008 | 06:08 AM
looking for 600whp and hopefully a mid ten with the car
Old Aug 27, 2008 | 06:36 AM
TheShodan's Avatar
Moderator
The S362 in the T3 .70A/R is capable of 600whp. Will it do "10s"? That's up to you the driver and your supplemental equipment. Don't rely only on the turbo to do what you're trying to do. Focus on the rest of your setup, and seat time. If you know how to drag race, you'll eventually do it.
Old Aug 27, 2008 | 06:52 AM
Default Re: (TheShodan)
well ive got two years in the seat of this car so hopefully wont be that hard to do we where running 11.88 @119 with 338whp on a precission t3 57 trim 60 ar and basic revhard kit. cast mani revhard tiny fmic turbosmart wastegate 550 injectors and 19.5lbs so im hoping this will put us over the edge for tens.
Old Aug 27, 2008 | 07:07 AM
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flatblackhatch &raquo;</TD></TR><TR><TD CLASS="quote">well ive got two years in the seat of this car so hopefully wont be that hard to do we where running 11.88 @119 with 338whp on a precission t3 57 trim 60 ar and basic revhard kit. cast mani revhard tiny fmic turbosmart wastegate 550 injectors and 19.5lbs so im hoping this will put us over the edge for tens.</TD></TR></TABLE>
work on your suspension and bump power up to 380Whp or 400Whp and work on getting good 60ft. times and you will be in the 10's. you dont need 600whp to try to muscle the car down the track
Old Aug 27, 2008 | 07:25 AM
the turbo we had ran out of room i was pulling 1.7 60s with that setup which are decent. im just hoping to hit tens as far as the car go its got everything on it suspension wise to help hook it up i know its going to take some tinkering to get it to ten but im just wondering if with that setup we have potential. its b16 stock bore sleeved aries pistons 9.1 to 1 crower rods stock crank ferra valve train springs retainers all that good stuff using gsr cams victor x mani peakboost topmount mani precission 650fmic 3in dp tuning using s300 and running 30lbs.
Old Aug 27, 2008 | 08:16 AM
spoolin turbo s's Avatar
you could prolly pick up 50 or more whp by swapping out those cams for some skunks
Old Aug 27, 2008 | 08:18 AM
Default Re: (spoolin turbo s)
ran skunks actually made less hp with those
alex288
Apr 28, 2006 12:50 PM
twisted_jdm_b16
Jan 13, 2006 01:02 PM
my crx is rhd
Dec 22, 2004 10:59 AM
type Gendy
Nov 13, 2002 07:06 PM
