oil restrictor??
Old Aug 19, 2008 | 06:56 PM
b18 hatch mike's Avatar
Default oil restrictor??
is this a good oil restrictor ?
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Aug 19, 2008 | 08:36 PM
Mr. Em1's Avatar
looks fine, it should work, the one i have is a little gold fitting. but that looks like it works a bit nicer
Old Aug 19, 2008 | 08:42 PM
Default Re: (Mr. Em1)
well i hope so just bought it
Old Aug 19, 2008 | 08:48 PM
Stealthmode Performance's Avatar
Default Re: (b18 hatch mike)
I've never purchased one of those, but I've used thousands of function7 drain flanges over the years. I've never ever had an issue with their machine work, and I wouldn't expect you to have one either.
Old Aug 19, 2008 | 08:51 PM
Default Re: (Stealthmode Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealthmode Performance &raquo;</TD></TR><TR><TD CLASS="quote"> I've never purchased one of those, but I've used thousands of function7 drain flanges over the years. I've never ever had an issue with their machine work, and I wouldn't expect you to have one either. </TD></TR></TABLE>
good i hope i dont
Old Aug 19, 2008 | 09:14 PM
South Bay Surfer's Avatar
From: South Bay, Torrance/Carson, CA, United States
I've read that if you're using a -3an oil feed line you don't need an oil restrictor.
Old Aug 20, 2008 | 07:47 AM
Default Re: (South Bay Surfer)
where did i hear that.
Old Aug 20, 2008 | 08:18 AM
marcj's Avatar
I have the exact same thing, but i think it's for ball bearing turbos.. the hole is a little bigger than a needle hole.. i'm going to drill mine out since i'm running a journal bearing turbo, probably half the side of a -3 AN line would feed.. any suggestions?
Old Aug 20, 2008 | 09:42 AM
Default Re: (marcj)
well i have a journal bearing turbo so what size drill bit would be best
Old Aug 20, 2008 | 11:05 AM
marcj's Avatar
from what I was told anything close to a -3 AN inner diameter would be fine.
Old Aug 20, 2008 | 12:29 PM
Default Re: (marcj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcj &raquo;</TD></TR><TR><TD CLASS="quote">from what I was told anything close to a -3 AN inner diameter would be fine.</TD></TR></TABLE>
He's right. You don't want to risk oil starvation with the use of an oil restrictor if you don't need one.
Old Aug 20, 2008 | 01:13 PM
so u are saying this is fine
Old Aug 20, 2008 | 02:06 PM
thelate1's Avatar
^^i wouldn't.
Old Aug 20, 2008 | 02:52 PM
TheShodan's Avatar
Moderator
Default Re: (thelate1)
The one that you're posting on ebay seems to claim that it is a 1.6mm opening (.062"). That's a bit big for small to medium sized GT ball-bearing cartridges which need only a .88mm (.035"). If you are indeed running the smaller to medium sized ball-bearing GT units (GT2860RS to GT35R sizes) this is not the one for you. Check with ATP for the correct application.
Old Aug 20, 2008 | 07:48 PM
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">The one that you're posting on ebay seems to claim that it is a 1.6mm opening (.062"). That's a bit big for small to medium sized GT ball-bearing cartridges which need only a .88mm (.035"). If you are indeed running the smaller to medium sized ball-bearing GT units (GT2860RS to GT35R sizes) this is not the one for you. Check with ATP for the correct application.</TD></TR></TABLE>
Old Aug 20, 2008 | 09:00 PM
TheShodan's Avatar
Moderator
Than a restrictor is not recommended if using a -3AN feed line from the oil sending unit on a honda. DO NOT USE ONE AT ALL. You don't want to risk oil starvation.
Old Aug 20, 2008 | 09:13 PM
i got the fast turbo oil supply and return kit these are the specs so i guess i dont need one ?
- Complete full kit with all the turbo and engine fittings, adapters and all hardware
- -3AN Goodridge Crimp hose assembly
- BSPT adapter to eliminate the chance of cracking or leaking from the block
- Easy to install !
Old Aug 20, 2008 | 09:26 PM
jasoncrashtech's Avatar
i have a t3t4 journal bearing turbo and i'm looking for a oil line kit for it also. could you send me a link to check out the one that you got?
Old Aug 20, 2008 | 09:37 PM
B R Fittings's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18 hatch mike &raquo;</TD></TR><TR><TD CLASS="quote">i got the fast turbo oil supply and return kit these are the specs so i guess i dont need one ?
- Easy to install !
You don't need a oil restrictor. What I always tells customers is to just run a -3 line without a restrictor, and if you notice oil pushing past the seals then add a restrictor (.060"). The worst thing you can do is starve the turbo of oil and that will be a $600 mistake.
GT turbos are a whole different story.
Old Aug 21, 2008 | 10:57 PM
- Easy to install !
Old Aug 22, 2008 | 12:01 AM
Yah you don't need one with the -3an. The most important thing to check in order to preserve the seals of your turbo is to have a good downward angle on the return line. The return line is gravity-driven so make sure there is absolutely no uphill travel.
Old Aug 24, 2008 | 10:46 AM
i will post a pic of it soon
rdeezy78
Jan 2, 2007 08:17 PM
playahwitgame
Jun 14, 2006 11:34 AM
RemerLex11
Jul 6, 2005 03:17 PM
warwagon
Jun 4, 2005 08:24 AM
mickey513
Apr 23, 2003 04:16 PM
