boosting a gsr
Old Aug 20, 2008 | 04:49 PM
ty91184's Avatar
Default boosting a gsr
got a stock gsr motor whats safe to boost to ? wondering the max power so i could have a safe boosted gsr i also live in the pittsburgh area anyone know of any good tuners in the area?
Old Aug 20, 2008 | 05:34 PM
umair's Avatar
270 WHP should be good.
Old Aug 20, 2008 | 05:48 PM
Koopey's Avatar
* B A N N E D *
Default Re: (umair)
PSI wise? 9psi safely. 12psi is pushing it.
Expected power? 270whp/320whp on 12psi... around there.
All depends on your turbo size, manifold, downpipe size and tuner.
P.S. - Please buy a s2/edelbrock intake manifold when you buy your turbo parts. GSRs have 2 piece intake manifolds which seem to hold back the motor from making power.
Old Aug 20, 2008 | 07:15 PM
a1320addict's Avatar
Default Re: (Koopey)
This has been covered many times.
PSI is not what you need to be concerned with, horsepower is what will break stock components.
With an efficient tuner, 300whp daily is not a lot to ask for or unsafe, there's tons of guys on here who've pushed the limits of the stock motors and have had great success. Obviously it would be wise to ensure the motor is in heatlhy condition before planning anything.
On a stock motor, the key to having a reliable setup that will make power is using quality parts, proper tuning, and proper maintenance.
Old Aug 20, 2008 | 07:31 PM
EG92Turbo's Avatar
Default Re: (a1320addict)
I'm confused. How do you make horsepower on a turbo set-up without PSI?
Of course horsepower will do it but you have to crank a boost controller which turns the PSI up which will then make more horsepower.
Old Aug 20, 2008 | 07:38 PM
VTECth1s's Avatar
Default Re: boosting a gsr (ty91184)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ty91184 &raquo;</TD></TR><TR><TD CLASS="quote">got a stock gsr motor whats safe to boost to ? wondering the max power so i could have a safe boosted gsr i also live in the pittsburgh area anyone know of any good tuners in the area?</TD></TR></TABLE>
What are your goals first of all? What turbo do you plan on using? Then from there you can estimate how much psi to push. Then it will determine how much whp your putting down.
Old Aug 20, 2008 | 07:47 PM
VI Massive's Avatar
Default Re: (EG92Turbo)
You do need PSI, but what they're trying to say is, you could make the same or more power with a larger turbo, but with with a lower PSI. The key here is airflow which is volume of air and not PSI which is a pressure/force. High PSI levels are not always desirable(Heat).
Old Aug 20, 2008 | 07:53 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Koopey &raquo;</TD></TR><TR><TD CLASS="quote">PSI wise? 9psi safely. 12psi is pushing it.
P.S. - Please buy a s2/edelbrock intake manifold when you buy your turbo parts. GSRs have 2 piece intake manifolds which seem to hold back the motor from making power.</TD></TR></TABLE>
i guess im in trouble I made more than that,
Guys psi is irrelevant. power is the factor.
Old Aug 20, 2008 | 07:58 PM
EG92Turbo's Avatar
Default Re: (HybridcivicLS-T)
I was basing my number off the other 239470235702 GSR turbo set-ups out there that have t3/t04e .57 trims.
But yes, if you get something like a 30R/35R, you are likely to make 320whp on 9psi.
My friend made 385whp on 14PSI w/ a 35R, F-R top mount, S2 IM/TB & S2S1 cams on a B16.
Old Aug 20, 2008 | 08:00 PM
Default Re: (VI Massive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG92Turbo &raquo;</TD></TR><TR><TD CLASS="quote">I'm confused. How do you make horsepower on a turbo set-up without PSI?
Of course horsepower will do it but you have to crank a boost controller which turns the PSI up which will then make more horsepower.</TD></TR></TABLE>
lmao..Obviously you need boost pressure to make horsepower on a turbo application, I was inferring that you need to realize your goals and concerns should not be based off how much psi it's going to take, but more focused on what the weakest link can handle, in this case..stock internals, which will fail at certain power levels. Yes, psi needs to be considered i.e. Your understanding that with more boost pressure comes more heat, which has the potnetial to lead to detonation and damage.
Old Aug 21, 2008 | 06:53 AM
TheShodan's Avatar
Moderator
For his goals, this is simply not yet necessary. Many GS-Rs have done quite well with their stock intake manifolds until they've reached a higher power level in which a larger plenum would necessary anyway.
Old Sep 10, 2008 | 12:30 AM
samayoa_josue1989's Avatar
i have a bone stock gsr tuned by Jason Hunt......301.2HP on 11psi....and 405.9HP on 19 psi w/ 116 of course.....all i have is a 3mm cometic head gasket....and is still runnin PERFECT!!! In fact i'm getin ready for a bigger set up and crank up da boost....trust me stock is da best for street....i still have fully built motor...but i rather stock for street 10 times better
Old Sep 16, 2008 | 07:08 PM
hamizle's Avatar
my gsr i got 12psi e85 top mount sc34 and make 410whp
Old Sep 16, 2008 | 07:56 PM
Turbo-charged's Avatar
Default Re: (hamizle)
we usually stop about 300-350 on a stock motor with a good turbo set up. have gone as high as 430 on c16. i think the most boost ive put on a stock gsr was about 22-24psi on race gas. obviously there are risks associated with doing that
akcapr
Oct 4, 2010 04:03 PM
99DC2GSR
Mar 14, 2007 12:37 PM
90teg
Mar 16, 2006 02:43 PM
94integragsr
Jul 27, 2005 08:06 AM
Nid Styles
Jan 25, 2004 12:30 PM
