new motor
Old Aug 20, 2008 | 03:04 AM
avotegra's Avatar
Default new motor
just finish with the new motor........should i break in the motor first then boost or...tune and boost will breaking the motor in...........which one is better.......motor is built for boost with 9.8.1 com....
Old Aug 20, 2008 | 07:54 AM
b18 hatch mike's Avatar
Default Re: new motor (avotegra)
i would break it in first
Old Aug 20, 2008 | 12:17 PM
ITR-EKcoupe's Avatar
Default Re: new motor (b18 hatch mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18 hatch mike &raquo;</TD></TR><TR><TD CLASS="quote">i would break it in first </TD></TR></TABLE>
x2
thats what im doin with my new motor. im sure with a good tune and if you didnt boost too hard im sure it'd be fine to break it in, but im not about to chance it with my 3 g's.
Old Aug 20, 2008 | 12:21 PM
sp00led's Avatar
Default Re: new motor (ITR-EKcoupe)
Break it in on the dyno with boost. That is what i've done for both of my motors.
https://honda-tech.com/zerothread?id=878397
Old Aug 20, 2008 | 01:18 PM
Jintegragsr97's Avatar
Default Re: new motor (sp00led)
haha thats exactly what I'm going to do, I just hope my motor doesnt run too lean while i drive it 10min to church tuning
Old Aug 20, 2008 | 11:02 PM
avotegra's Avatar
Default Re: new motor (Jintegragsr97)
what if your piston is 9.8.1 comp....can you still run with stock ecu untill motor break it.........would that throw the stock ecu off............
Old Aug 20, 2008 | 11:35 PM
Na dont do it! Too risky, your pistons might scrape your sleeves like in those pictures The most i would do is drive it no more than 15min to the dyno to tune it and break it in there.
Old Aug 21, 2008 | 12:14 AM
avotegra's Avatar
i mean just use stock injector stock everything no turbo watsoever............just like the car is stock....will that be ok....or do i still need to tune becuz of the diff..in compression...
Old Aug 21, 2008 | 01:15 AM
yeah definately, I mean if you have cams only it would be a diff story but I think if you change the pistons then it wont be ok.
Old Aug 21, 2008 | 09:26 AM
avotegra's Avatar
Default Re: (Jintegragsr97)
so its a must tune motor..if piston is change...can't use stock ecu to break motor in then..........how do ppl with like 9.0.1 compression..break in there motor.......
Old Aug 21, 2008 | 01:23 PM
Default Re: (avotegra)
Tune it.
Old Aug 21, 2008 | 01:32 PM
JRSC01GS-R's Avatar
on my piston and rod gsr, i have 9.5:1 cp pistons, i started it up in garage to check for leaks and then i rented a uhaul car dolly for $50 and towed my car to tuner, these motors cost too much to risk anything
and we broke it in with boost
Modified by JRSC01GS-R at 3:18 PM 8/21/2008
Old Aug 23, 2008 | 05:24 AM
rwcdrums's Avatar
Default Re: (JRSC01GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRSC01GS-R &raquo;</TD></TR><TR><TD CLASS="quote">on my piston and rod gsr, i have 9.5:1 cp pistons, i started it up in garage to check for leaks and then i rented a uhaul car dolly for $50 and towed my car to tuner, these motors cost too much to risk anything
Modified by JRSC01GS-R at 3:18 PM 8/21/2008</TD></TR></TABLE>
That's what I'm doing. I agree with you 100%. Why take the risk?
Old Oct 7, 2008 | 09:39 AM
jry2598's Avatar
Default Re: (rwcdrums)
heard your built sleeved motor pulled a amazing 250 less horsepower .....dang all that for so little horsey......its your turbo that is holding you back especially your setup. Even your boy with the LS ebay turbo pulled that on all stock. but living in cali with all their carb bullshit is wack, i should run low 12's when im done with mine.
Old Oct 7, 2008 | 01:39 PM
LastGenEK's Avatar
Default Re: (jry2598)
Boost seats those rings faster than anything
Ofcourse tuned
Old Oct 7, 2008 | 01:43 PM
JRSC01GS-R's Avatar
Default Re: (LastGenEK)
my rings were pretty much seated after 3 or 4 dyno pulls
DAteg402
Dec 4, 2008 03:09 AM
IntegraType-R
Oct 6, 2006 04:57 PM
lopaka07
Jun 6, 2005 08:43 PM
s2kkid
Sep 11, 2004 07:36 AM
