greddy type s Blow off valve whistling???
Old 08-20-2008, 01:55 PM
accord99power's Avatar
Default greddy type s Blow off valve whistling???
i have the greddy type s BOV, and at low rpm or after a quick rev and upon returning to idle i get theis wierd whistling noise, like its whislting a song for acouple seconds. any clue?
Old 08-20-2008, 01:56 PM
jessec817's Avatar
same thing happened to mine its too lose.
Old 08-20-2008, 02:10 PM
thewrai6th's Avatar
Default Re: (jessec817)
It's just enough pressure in the charge pipes to leak/squeak/whistle the BOV, it's normal. If you tighten the spring up to a stiffer setting, you may get compressor surge.
Try adjusting the setting and see what works best for you. The stiffer the setting, the more pressure it will take to blow off. Mine blows off at >2psi, but it does whistle. I don't even notice anymore.
Old 08-20-2008, 02:36 PM
Default Re: (thewrai6th)
thanks for the reply i belive when i ightened it all the way it did the same thing but i will try again.
Ultra Jurassic
07-10-2005 06:40 AM
B16Civic93
03-08-2005 07:36 AM
hotimportcrx
02-06-2005 07:33 PM
SpoolinSol
04-25-2002 02:02 PM
philo
01-22-2002 08:55 PM
Quick Reply: greddy type s Blow off valve whistling???
