water cooled turbos
Old Aug 29, 2008 | 09:52 AM
1junkycivic's Avatar
Default water cooled turbos
Does the turbo work better meaning spool up better with lines or without?
Old Aug 29, 2008 | 10:31 AM
Civicman86's Avatar
Default Re: water cooled turbos (1junkycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1junkycivic &raquo;</TD></TR><TR><TD CLASS="quote">Does the turbo work better meaning spool up better with lines or without?</TD></TR></TABLE>
the lines are just there to cool down the center section (bearings).
Old Aug 29, 2008 | 10:43 AM
Default Re: water cooled turbos (Civicman86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 &raquo;</TD></TR><TR><TD CLASS="quote">
the lines are just there to cool down the center section (bearings). </TD></TR></TABLE>So will it make turbo work better?
Old Aug 29, 2008 | 10:56 AM
SD_Lurker's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1junkycivic &raquo;</TD></TR><TR><TD CLASS="quote">So will it make turbo work better?</TD></TR></TABLE>
Does using radiator fluid in your car make it work better? Besides the obvious fact it will over heat and blow up with out it. That should help answer your question.
Old Aug 29, 2008 | 11:04 AM
Sr420Det's Avatar
Yeah the radiator works better than say a air cooled Porsche.
Default Re: water cooled turbos (SD_Lurker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker &raquo;</TD></TR><TR><TD CLASS="quote">
Does using radiator fluid in your car make it work better? Besides the obvious fact it will over heat and blow up with out it. That should help answer your question. </TD></TR></TABLE>Why is everyone on here smart a.s and cant answer with info to help others.So do you have anything to add that is useful?
Old Aug 29, 2008 | 11:18 AM
SD_Lurker's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1junkycivic &raquo;</TD></TR><TR><TD CLASS="quote">Why is everyone on here smart a.s and cant answer with info to help others.So do you have anything to add that is useful?</TD></TR></TABLE>
I JUST DID MAN. I ANSWERED YOUR QUESTION. Running water is going to do nothing for performance but if its a water cooled turbo I HIGHLY suggest you run it.
Old Aug 29, 2008 | 11:35 AM
linx's Avatar
I don't thing weather your center housing is water cooled or not will affect your spool time. The water cooled section just helps extend bearing life. hope this helps
thegeezerkid
Jun 14, 2008 10:56 PM
DurtyVdub
26
Jun 21, 2007 09:50 PM
Street2uned ef
Sep 4, 2006 07:12 PM
effinnwackk
37
Apr 13, 2005 11:43 PM
Alberto
Apr 30, 2004 04:09 AM
