read these plugs for me
knowing nothing other than the vehicle is turbocharged, read these for me and tell me what you think.
read as cylinder #1 on right and cylinder #4 on left.
bigger versionhttp://www.superhonda.com/phot...t=513
autolite, WTF.
#3 looks rich or oil soaked, #2 looks alittle lean. and there are deposits on the ground electrodes, additives? what fuel station are you using?
check your fuel psi, and i suggest a leak down on #2 & #3
Modified by 95dxsir2 at 8:12 PM 8/25/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 »</TD></TR><TR><TD CLASS="quote">#1 looks normal
the rest look leaned out
run your car down the block then pop the spark plugs and check them then </TD></TR></TABLE>
thats what I was thinking except for #3 might have a bad valve stem seal as well.
its a stock 86 svo mustang running in premium road @16psi
it felt like it was starting to lose speed and I was suspecting a faulty fuel pressure regulator. this makes me think a bit more leaning in that direction.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 »</TD></TR><TR><TD CLASS="quote">autolite, WTF.
yep, until you get above 35psi, everything else sucks in these engines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz »</TD></TR><TR><TD CLASS="quote">
yep, until you get above 35psi, everything else sucks in these engines.</TD></TR></TABLE>
yeah i hear ya i run autolite 3924 in my ram
oops, i went *** backwards....lol
there fixed, and i wouldn't be running it with the way #2 looks, boosting
don't want a hole or melt down
Modified by 95dxsir2 at 8:13 PM 8/25/2008
