Tial 44mm wastegate V-band Clamp......
Hey guys I'm putting my 44mm waste gate on my manifold and when i tighten down the clamp it does not close all the way. like it does not connect to make a full circle. I'm wondering if i can get some info on if this is right or wrong. I thought maybe i had the wrong clamp cause they do have a inlet and outlet clamps. I'm not sure what the difference is. Any info would be great. Thanks guys.
Kevron
Modified by KevronsEG at 7:49 AM 8/28/2008
Kevron
Re: Tial 44mm wastegate V-band Clamp...... (SD_Lurker)
i will post pics today. Its close to closing all the way. i have not tried to really get it tight as i'm just test fitting stuff and kinda seeing how everything is. I will get pics up though. Thanks
Re: Tial 44mm wastegate V-band Clamp...... (KevronsEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevronsEG »</TD></TR><TR><TD CLASS="quote">Hey guys I'm putting my 44mm waste gate on my manifold and when i tighten down the clamp it does not close all the way. like it does not connect to make a full circle. I'm wondering if i can get some info on if this is right or wrong. I thought maybe i had the wrong clamp cause they do have a inlet and outlet clamps. I'm not sure what the difference is. Any info would be great. Thanks guys.
Kevron
Modified by KevronsEG at 7:49 AM 8/28/2008</TD></TR></TABLE>
the inlet and outlet clamps are two different sizes...that may be your problem
Kevron
Re: Tial 44mm wastegate V-band Clamp...... (TiAL)
Well this is what i'm doing. manifold has 44mm flange. i have 38mm wastegate so i bought one of the adapters from ATPturbo.com, i bought a inlet clamp. Should i have an outlet clamp? I have pics too just need to upload them. thanks for the help so far
SupraDai
01-10-2005 06:31 PM
