IACV leaking boost
Old Aug 24, 2008 | 05:12 AM
dartonh22's Avatar
Default IACV leaking boost
i have a h22 turbo and i did the boost leak test to 11 psi and sprayed soapy water on my iacv and its bubbling out on the end of it,(not where it seals to the manifold but on the capped end) is this normal and is there any way to fix it besides buying a new one?
Old Aug 24, 2008 | 06:55 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: IACV leaking boost (dartonh22)
is it causing any issues?
if not let it eat.
Old Aug 25, 2008 | 03:48 AM
dartonh22's Avatar
Default Re: IACV leaking boost (boostedcivicsir)
its kinda messing with the idle but mainly causing a boost leak which hinders power, i fixed some other leaks and it made a big difference all of which were smaller than this one leak, i have a spare one that i rtv'ed and am waitning for it to dry but i kinda doubt it will hold, i would like to hold 16 psi without it leaking down quite as fast if not at all.
Old Sep 5, 2008 | 12:39 PM
dartonh22's Avatar
well, to those that may have the same problem i threw a bunch of rtv around the area that was leaking and it helped a little but; it still creates small bubbles when sprayed with soapy water, definetly holds more boost though.
Ultra EK9
Feb 13, 2011 06:48 AM
B20luda
Dec 2, 2010 03:33 AM
playahwitgame
Jul 9, 2006 09:25 PM
bey
Feb 18, 2004 11:19 AM
93TurboSi
Oct 16, 2003 06:04 PM
