H2B QSD TWIN
well i totaly finish my h2b swap on my car i go and turn on the car for a test drive and i hear a griding noise coming out off the trany only when u engage the clutch when u disengage it stop so i figure its coming out off the clutch assembly well i remove the transmision out nad it appers like there a problem somewere betwwen the fly wheel and the h2b kit itself such as i dont hear to many h2b guys using a twin disc on this set up so ur opinion i s great full on what can be going on here some pics
this is with the bolts that the qsd kit came with install in the twin flywheel
[IMG][/IMG]http://i35.photobucket.com/alb...8.jpg
now this what it looks like with out a bolt
http://i35.photobucket.com/alb...0.jpg
now i custom made these washers cause the qsd bolts were tight before it could touch the flywheel
http://i35.photobucket.com/alb...1.jpg
here is with a stock b-series bolt but not enough thread to torque right
http://i35.photobucket.com/alb...2.jpg
now here are the 2 bolts of the fly wheel stock and the qsd ones
http://i35.photobucket.com/alb...3.jpg
here is the twin disc clutch and it appears the when i am engangin its not stoping the clutch completely look at the disc close and i am using the twin throw out bearing what ur opinion can be to fix this problem ,,,bigger spacer or just sell the clutch and get a stock fly wheel with a stage 5 that the way qsd design it [freak]ed dam
http://i35.photobucket.com/alb...6.jpg
yea the thing is that it only makes noise when the clutch is press and kept press if u realese and let it idle u hear no noise ..the noise is like a sord fight goin on on the trany side and the pilot bearing is new it came with the clutch kit
integraautox
Jan 23, 2003 01:14 PM
