help
Old Aug 25, 2008 | 08:09 AM
93hatchy08's Avatar
Default help
sorry guys kinda new at this. anyway whay size injectors would i need to run 15psi max?
Old Aug 25, 2008 | 08:10 AM
TheShodan's Avatar
Moderator
Default Re: help (93hatchy08)
too vague. No turbo specs, no engine application, no "tech" = No answer.
Old Aug 25, 2008 | 08:13 AM
chimmike's Avatar
1600cc injectors, minimum. And 3 walbro fuel pumps with a 1000lph in line pump.
Old Aug 25, 2008 | 08:14 AM
93hatchy08's Avatar
Default Re: help (TheShodan)
like i said new at this. Anyway
lsvtec
skunk2intake
gsr cams
walb255 pump
Old Aug 25, 2008 | 08:16 AM
93hatchy08's Avatar
oh really thanks chimmike your a real help.
Old Aug 25, 2008 | 08:23 AM
chimmike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hatchy08 &raquo;</TD></TR><TR><TD CLASS="quote">oh really thanks chimmike your a real help.
your question gave us none of the required information to determine an answer.
Read the FAQ's.
Old Aug 25, 2008 | 08:34 AM
93hatchy08's Avatar
Default Re: help (chimmike)
lsvtec
skunk2intake
gsr cams
walb255 pump
eagle rods
je pistons
t3t4 TURBO!
what size injectors do you think i should have? 750cc? bigger? smaller?
Old Aug 25, 2008 | 08:55 AM
totsie7944's Avatar
just to be safe I'd run 1000cc peak and hold rc injectors, but any 1000cc wil be fine. I'm thinking you might max out the duty on 750's
Old Aug 25, 2008 | 09:08 AM
chimmike's Avatar
Default Re: help (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">just to be safe I'd run 1000cc peak and hold rc injectors, but any 1000cc wil be fine. I'm thinking you might max out the duty on 750's</TD></TR></TABLE>
15psi on a t3/t4, even 60 trim, isn't going to max out the duty cycle on 750cc injectors.
Old Aug 25, 2008 | 09:11 AM
twkdCD595's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">
15psi on a t3/t4, even 60 trim, isn't going to max out the duty cycle on 750cc injectors. </TD></TR></TABLE>
x2... should be good on a 750cc and have room to grow.
Old Aug 26, 2008 | 11:40 AM
93hatchy08's Avatar
Default Re: help (twkdCD595)
thanks guys you have been more than helpfull. and chimmike thanks for comin around.
Oh one more question my budy has almost the same setup 450cc should be ok for 12 pounds. right?
Old Aug 26, 2008 | 12:24 PM
chimmike's Avatar
again, it depends on turbo size.
if he's running a .57 trim t3/t4, those injectors will be maxed out before 11psi.
For a general rule of thumb, you want to tune for power, not boost pressure.
440s/450cc injectors will max out around 300whp. That's probably about 8-10psi on a .57 trim t3/t4. I'd run at least 550cc injectors or larger for 11psi on a .57 trim.
Old Aug 26, 2008 | 01:32 PM
yakuza's Avatar
For god sake, just use an injectors calculator and save us the trouble
http://www.rceng.com/technical.aspx
http://www.witchhunter.com/injectorcalc1.php4
b20EGvtec
Mar 18, 2009 06:21 PM
zach1288
Sep 4, 2008 12:03 PM
motrayEG6
62
Jan 9, 2007 04:34 AM
