boosting less than 10psi is useless
Old Apr 28, 2002 | 06:46 PM
simonsez's Avatar
Default boosting less than 10psi is useless
a friend of mine told me that boosting less than 10psi is pretty much useless. he said the reason why people use turbo is to use the boost that can only be obtained from higher psi. i know he's full of sh*t, but what do you guys think? i'm planning on boosting my '90 LS and keeping the psi at around 7 or 8 which i heard will give me about a 75hp increase. to me, that's all i really want right now because i don't race much anyways but would like an increase in power for when i do.
also, does anyone how how hard it would be to install a turbo system on a g2 integ? i'm on a budget and am looking to do a custom setup.
Old Apr 28, 2002 | 06:52 PM
MiraiZ's Avatar
Default Re: boosting less than 10psi is useless (simonsez)
Some people are getting like 300+whp at less than 10psi...if that's useles.his standards are bit wacked
Old Apr 28, 2002 | 06:54 PM
DragII's Avatar
25 Year Member
Default Re: boosting less than 10psi is useless (MiraiZ)
yup....file those comments in your "dumbass" bin.
Old Apr 28, 2002 | 07:15 PM
DA666's Avatar
Default Re: boosting less than 10psi is useless (SuperDragII)
hey,
i have a custom seeup in my g2, and its way tight.....i have a tubular sfp manny, and had a t3t4, but it wouldnt fit unless i grinded the block or got a new manny.....so i opted, well had no choice, to go with a t3 super 60....it spools quicker, 2500 rpm, and fits perfectly.......we are still working out quirks, but when doneshould haul *** looking for like 240-260 wheel power.....custom setup, spearco cooler,2.5 downpipe to 3" full exhaust, no cat.....boostin hopefully 6-10psi......we will see....good luck with ur custom setup.....i should have some pix up soon..........
Old Apr 28, 2002 | 07:26 PM
tonydatyga's Avatar
And don't forget to empty it...
Old Apr 28, 2002 | 08:33 PM
sushibug's Avatar
that **** cracked me up
Old Apr 28, 2002 | 10:27 PM
simonsez's Avatar
Default Re: boosting less than 10psi is useless (94hondahybrid)
i knew i could count on you guys to back me up. thanks for all your input.
94hondahybrid: thanx for the link to the site. that's exactly what i needed.
Old Apr 28, 2002 | 11:34 PM
Teg4e's Avatar
he is stupid, install is pretty easy, and check out this http://coolazz.tripod.com/turbo.html
wow, that's a helpful site. couple mistakes, but the important stuff is right
Old Apr 29, 2002 | 01:06 AM
PrecisionH23a's Avatar
no offense, but your buddy is a moron. ask him why less then 10psi is useless, id like to see what he says.
Old Apr 29, 2002 | 01:13 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: boosting less than 10psi is useless (GudeH23a)
time for you to make new friends...for real, does he drive a boosted moded car? If not, tell him to go **** himself. Don't put opionions of something and state it as fact. It's just his opinion, no matter how wrong he is... But for real, what a dork.
B and B
Feb 18, 2013 12:13 AM
crxautox
Mar 5, 2011 09:47 AM
gosu08
Mar 2, 2008 03:38 AM
90 integra
Aug 24, 2004 06:34 AM
rexandfx
May 1, 2004 10:03 AM
