Semi-tuned 10 psi!!
Old Apr 30, 2002 | 04:34 PM
TurboSedan's Avatar
New User
Default Semi-tuned 10 psi!!
I cranked the Joe P again, this time to 10 psi. In doing this, I noticed that between 6k-7k rpms I leaned a little bit. I turned the AEM FPR up to 46 psi fuel pressure and tried it again. It never went below .80 volts. All I need now is to have Tom Payne tune my Hondata map so that I am spot on at lower rpms and part throttle. It runs a little too rich everywhere but 5k-7k at full throttle. Still, at 10 psi it is faster than hell. My left shoulder aches a little from fighting the torque steer at full throttle from 4k-7k in 2nd gear lol!!
Old Apr 30, 2002 | 04:52 PM
Trac226's Avatar
Default Re: Semi-tuned 10 psi!! (97CivicFerio)
Man, you can't stop turning up the boost can ya?
Old Apr 30, 2002 | 05:02 PM
TurboSedan's Avatar
New User
Default Re: Semi-tuned 10 psi!! (Trac226)
LOL, well I have to stop now because I am only mapped to 10 psi on my Hondata map. Once Tom Payne goes to work for me I will have him map to to like 15-20 psi I guess. Just in case I build the motor and want to get crazy hehe.
Old Apr 30, 2002 | 05:53 PM
BLKCRX's Avatar
hey man what size turbo you running ???
Regards James
Old Apr 30, 2002 | 05:54 PM
92HB_HB's Avatar
ur boostn 10 psi on ur stock block?? man i was advised by the guys at payn to stay around 9 psi or so on my stock LS block.. oh yeah u got a clutch yet or still runnin the stocker?? if ur still on the stock, prepare to upgrade within weeks if u boost often..
mang, we gots to meet up sometime to check out each others rides, just an idea..
Old Apr 30, 2002 | 06:16 PM
TurboSedan's Avatar
New User
Default Re: Semi-tuned 10 psi!! (BLKCRX)
I am running a T3 60 trim and .48 A/R turbine.
Old Apr 30, 2002 | 06:17 PM
inspyral's Avatar
Default Re: Semi-tuned 10 psi!! (92HB_HB)
Old Apr 30, 2002 | 06:20 PM
TurboSedan's Avatar
New User
Yeah, stock block D16. As long as there is no detonation and it does not lean out up top everything should be fine. I also do have a stock clutch, it still feeels fine after boosting for almost two weeks. I am aware of the clutch so I kind of baby it a bit while launching.
I would like to meet up at some point dude, sure.
[Modified by 97CivicFerio, 10:21 PM 4/30/2002]
Old Apr 30, 2002 | 06:48 PM
maxim's Avatar
The d16 can take up to 14psi on the stock block. I met a guy here in Houston that is doing that without sleeves or a block guard, just GE rods and pistons. This is the first guy I have met that actually would rather have the d16 than the b16 for turbo apps, says it's more reliable. I dunno, I'm still sceptical about that claim, but I guess it makes sense.
Old Apr 30, 2002 | 06:53 PM
TurboSedan's Avatar
New User
Default Re: Semi-tuned 10 psi!! (maxim)
That is great to hear that there are D16 guys running that level of boost. I know I may be *pushing* it running 10 psi right now, but I also have a sensible right foot. Some days I hardly boost at all. I let the car warm up and cool down properly, a minute or two. Like I said earlier, I do not lean out or ping at all.
Old Apr 30, 2002 | 07:07 PM
maxim's Avatar
There's another guy on this board that is pushing 14psi with his stock d16 block, but I forget his user name.
Old Apr 30, 2002 | 07:44 PM
HXMan's Avatar
Do you know if you have to drive your car around at 15psi to map it out there? I would like to get my setup mapped for that so I don't have to drive to michigan when I get my engine built.
Old Apr 30, 2002 | 08:22 PM
B20C5 Turbo's Avatar
New User
97civic: When you say stock block.. Is the whole bottom end stock, or do you have forged pistons/rods in a stock casting? If you have the forged internals, you can run mad boost with good tuning on the stock casting.
Old Apr 30, 2002 | 10:48 PM
SIK IN DA HED's Avatar
New User
Default Re: Semi-tuned 10 psi!! (B20C5 Turbo)
next thing you know..
new thread:
Tuned 12 psi!!
Old May 1, 2002 | 12:29 AM
intekragsr's Avatar
Default Re: Semi-tuned 10 psi!! (dlplayboy)
damn u, making me jealous of my measly 6 pounds
Old May 1, 2002 | 02:23 AM
turbopanda's Avatar
is that me? my block is actually stock though, apart from the pistons and rods and blockguard.
D16 turbo ALL THE WAY BABY
(but i'm already bored.. B18C turbo on da way Heehhehehe)
Old May 1, 2002 | 04:15 AM
TurboSedan's Avatar
New User
I have stock pistons and rods, no blockguard, no nothing.
Max500
Engine Management and Tuning
Sep 13, 2011 06:49 AM
boosted96teg
Feb 4, 2007 06:53 PM
99lspwr
Oct 24, 2003 09:12 AM
DoriDoriboii
Mar 29, 2003 06:04 PM
TurboSedan
Apr 15, 2002 03:53 PM
