low idle...
Old May 1, 2002 | 12:06 PM
sushibug's Avatar
Default low idle...
okay.. my idle varies from 200rpm to 1100rpm. after some tweaking my idle is smooth but often it is pretty low... anyone know why? my a/f ratio says im stoich at idle... would the o2 sensor have anything to do with my idle? i had someone play around with it to install my a/f meter + turbo timer.
Old May 1, 2002 | 12:33 PM
Tomakit's Avatar
Default Re: low idle... (sushibug)
vacuum leak?
Tom
Old May 1, 2002 | 12:35 PM
sushibug's Avatar
Default Re: low idle... (Tomakit)
i was reading on another msg board that the o2 sensor helps control the idle. my downpipe is kind of loose right now, so im guessing that might be the culprit?
-=ZAK=-
Dec 30, 2008 06:48 AM
Ri5e
Oct 9, 2004 07:41 AM
SpoolnG2
Jan 8, 2003 09:13 AM
MeccaMan
Jan 28, 2002 05:33 PM
