My fuel press crazy?
Old Apr 28, 2002 | 08:29 PM
austrian type-R's Avatar
Default My fuel press crazy?
I have the AEM fuel press regulator where you can only adjust a fixed fuel press and no boost depending fuel press. I use the Walbro fuel pump from Jackson Racing and 440cc RC injectors.
At Idle I have 3 Bar (43.5 psi) fuel press and at WOT above 5000rpm it jumps up to 4.5 Bar (65.25psi). Why is this so? Should´nt I have always the same press, or at least near the same when idle and at WOT with the AEM fuel press regulator?
Old Apr 28, 2002 | 08:32 PM
sushibug's Avatar
Default Re: My fuel press crazy? (austrian type-R)
if your asking if the fuel pressure is supposed to go up when you are wot, yes it is... otherwise i dont understand yer question
Old Apr 28, 2002 | 08:33 PM
racerxadam's Avatar
the aem fpr raises fuel pressure 1psi per lb of boost. it always keeps the same difference between intake pressure to fuel pressure
[Modified by racerxadam, 12:34 AM 4/29/2002]
Old Apr 28, 2002 | 08:36 PM
Default Re: My fuel press crazy? (racerxadam)
realy?! I thought it will not rise the fuel press when boosting. I always thought it is just an fuel press regulator for an fix fuel press.
What is Hondas (Integra type-R) factory fuel press for idle and WOT.
Old Apr 28, 2002 | 08:47 PM
dustin's Avatar
The fuel pressure will always be baseline + manifold pressure (your boost level).
To keep fuel delivery constant, fuel injected cars have fuel pressure regulators that keep the pressure DIFFERENTIAL between the intake manifold and the fuel rail constant. If you are under 20psi of boost, then fuel in the rail is, in essence, being "restricted" by the boost pressure in the manifold. The fuel regulator will then add 20psi of fuel pressure (your boost level) to keep fuel pressure (and then delivery) constant for all load/boost levels.
Dustin
Old Apr 28, 2002 | 09:33 PM
Default Re: My fuel press crazy? (dustin)
Oh I understand. When in the combustion camber is boost it will press against the injected fuel. So it is a MUST to increse the fuel press when the press in the cylinder is higher to get the same amount of fuel into it, right.
So it is a common fuel press setting I have?
Thanks
Shmaa
Jul 7, 2006 04:59 PM
QUESTOYZ by RHanDy
Aug 24, 2005 06:52 PM
Quade
Apr 22, 2004 06:33 AM
toooslow
May 15, 2003 12:21 PM
iperez
Feb 8, 2003 10:55 PM
