POST pics of your oil return lines..
Old Apr 29, 2002 | 03:39 PM
92HB_HB's Avatar
Default POST pics of your oil return lines..
my return line is leaking and i'm going to redo the system.. can you guys post some pics of ur return setups?? wats the ID of your hoses you are using?? i'm thinking that 5/8" is sufficent for the return flow...
Old Apr 29, 2002 | 03:42 PM
TurboSedan's Avatar
New User
Default Re: POST pics of your oil return lines.. (92HB_HB)
I don't have a pic, but 5/8" which is 10AN is what most people use and it is fine.
Old May 2, 2002 | 02:14 PM
Shaun K's Avatar
I'm using -10 AN, no leaks so far with about 2000 miles on it:
Old May 2, 2002 | 02:17 PM
Smashback's Avatar
Using -8 AN line
[Modified by mplex2000, 11:18 PM 5/2/2002]
Old May 2, 2002 | 02:29 PM
maxim's Avatar
Default Re: POST pics of your oil return lines.. (mplex2000)
-8 AN? Do you have any blowby or do you use some kind of restrictor on the feed. I don't think I could do that with mine(-10AN).
Old May 2, 2002 | 02:33 PM
TurboSedan's Avatar
New User
Default Re: POST pics of your oil return lines.. (Shaun K)
Shaun, looks like your line has a slight upward turn right before it goes to the oil pan. That is generally not a good idea. Have you checked your turbo out to make sure the oil seals are alright? You want the line to be always routing downward, or maybe straight horizontal right at the end.
Old May 2, 2002 | 02:43 PM
maxim's Avatar
Default Re: POST pics of your oil return lines.. (97CivicFerio)
I don't know how you would have it going down with the dp in the way.
Old May 2, 2002 | 03:33 PM
qwkteg125's Avatar
Default Re: POST pics of your oil return lines.. (maxim)
flip the turbo around & your oil return will be straight:
Old May 2, 2002 | 05:36 PM
jamal-188's Avatar
Default Re: POST pics of your oil return lines.. (qwkteg125)
I think Arturbo was thinking or or actually selling oil return kits that he was making? Did this ever happen or am I smoking too much?
Old May 2, 2002 | 05:57 PM
sushibug's Avatar
Default Re: POST pics of your oil return lines.. (jamal-188)
never happened, i was forced to go outside, shop, and learn a thing or two about fittings.
Old May 2, 2002 | 06:06 PM
Shaun K's Avatar
Yeah, I've been meaning to shorten that line by about an inch which will make it more horizontal. So far no problems tho, oil seals are fine and it's not smoking. The picture actually exaggerates the amount it dips. I'll take some better pics soon.
Old May 2, 2002 | 06:21 PM
TurboSedan's Avatar
New User
Cool man, hopefully it will be fine.
Old May 2, 2002 | 06:48 PM
bigTom's Avatar
i hope u know the center section of the turbo should generally remain straight up and down
Boosted_Coupe
May 20, 2007 12:15 PM
k20em2
Oct 19, 2006 07:24 PM
BlueShadow
Dec 18, 2005 10:06 AM
birz
Jun 4, 2004 06:03 AM
FOrSfEd
Nov 21, 2003 07:39 PM
