SON OF A......IM PISSED!!!!!
Old May 1, 2002 | 02:58 AM
95IntegraGSRAZ's Avatar
Default SON OF A......IM PISSED!!!!!
Well got evryhting alredy to go in, and the damn turbo hits my trnsmition!!!! I have no clue what to do. What i really need is a spacer that would go inbetween the block and the exhust manifold. Do they sell these???? like for makeing custom headders or somehting. Please let me know, im in despret need!!!
Old May 1, 2002 | 03:03 AM
MiraiZ's Avatar
Default Re: SON OF A......IM PISSED!!!!! (civicvteckid)
how thick of a spacer?...have pics?
Old May 1, 2002 | 04:25 AM
D-Man's Avatar
Default Re: SON OF A......IM PISSED!!!!! (MiraiZ)
what turbo kit is this? you probably just have to loosen nuts on compressor housing and rotate it
Old May 1, 2002 | 04:39 AM
PrecisionH23a's Avatar
Default Re: SON OF A......IM PISSED!!!!! (D-Man)
Thats what it sounds like to me. Youll see 6 bolts on your compressor housing, loosen these a little and you can spin it to the angle needed. good luck
Old May 1, 2002 | 05:40 AM
rtype11's Avatar
not sure of the problem exactly, I could get you a header flange that will extend everything away from motor about 5/8".
Old May 1, 2002 | 07:06 AM
I have alredy turned the compressor housing and got some space.
Its a Garrett T3 turbo....
I have made up my mind. What Im going to do is throw my old exhust back on and wait to get a new turbo manifold. What should i use for the T3 turbo? IM looking at some Greddy Manifolds ritgh now but im not sure.
So for now the turbo is on hold....It was all going to well
So in three weeks maybe it will be on..... I hope......Grrrrrr
I need some to calm my self down
Old May 1, 2002 | 07:29 AM
dustin's Avatar
what manifold are you using now ??
Old May 1, 2002 | 07:42 AM
Mr. Vapor's Avatar
Default Re: SON OF A......IM PISSED!!!!! (dustin)
as far as i know, a greddy manifold wont fit a T3 turbo..........
holy **** your in canadaigua.......im 10 mins from you, i can help you if ya want!
[Modified by NYb16, 11:42 AM 5/1/2002]
Old May 1, 2002 | 07:43 AM
TurboSedan's Avatar
New User
Default Re: SON OF A......IM PISSED!!!!! (NYb16)
That is right, the same manifold for a T3/T4 will work with a straight T3 because the turbine section is the only thing that connects to the manifold. The Greddy manifold will not fit a T3 on it.
Old May 1, 2002 | 07:29 PM
ekb18c's Avatar
Hmmm your problem lies in the fact that you will have to notch the block a little bit. I'm guessing you mean the turbine is hitting the block close to the tranny.. Well you have to take a dremel tool and grind away some of material. Don't worry it's perfectly safe. Or you can try to turn the turbo to face the other way.
Old May 1, 2002 | 08:02 PM
Ri5e's Avatar
Default Re: SON OF A......IM PISSED!!!!! (ekb18c)
Do you have pics? Are you talking about the notch that comes out, near the CLUTCH bleed line? If so, thats the block...u can get a dremel and trim that SOB off.
Old May 2, 2002 | 03:01 AM
Default Re: SON OF A......IM PISSED!!!!! (BG Boost)
Sorry for not ahve any pics right now.
Actuly it need to come back so far that i woudl ahve to cut the Compressor housing, like in half. The exhust housing hits too. I was using a HF manifold.
WEll the cars back togeather, sniff sniff, without the turbo (for now).
NYb16, Is your car that electron blue color? Thats the only trubo civ i know of around here. Where about do you live? I have a 94 civ, and its dark purple, it used to be slamed to the ground but not anymore. Maybe we have passed eachother b4.???
Old May 2, 2002 | 04:58 AM
TGUNNER's Avatar
Agreed done it b4 it works just fine!! there is some metal on the block that can be grinded off.. you will jnot hurt anything!!! friend did it with a t4 on a gsr!!
Old May 2, 2002 | 05:39 AM
maxim's Avatar
Default Re: SON OF A......IM PISSED!!!!! (TGUNNER)
Make sure you loosen the bolts on the turbine to rotate the compressor outlet where it is facing straight down.
Old May 2, 2002 | 05:56 PM
Default Re: SON OF A......IM PISSED!!!!! (maxim)
I did turn the compressor housing and i did take some metal off of both the turbo and the transmition. Still no go. I would have to take so much off it would cut into the compressor housing to much and would make a whole. Like when it hits the trans. it needs to go back a good 2 inches to fit on proprly. I wish just a littel grinding woudl fix it but in the case its not going to. . I have found a HKS manifold that im buyng. So its all going to go in nicely in about 3 weeks.
hondaguyexsi
Aug 7, 2005 06:41 PM
94EGhatch
Aug 16, 2004 07:50 AM
BoostedD15B7
Feb 16, 2003 11:25 AM
Tofurky
Dec 7, 2002 04:48 PM
