Has anyone done the AFC Hack on 370cc Injectors (did Search)
I was wondering if anyone can steer me in the right direction in doing the AFC Hack
with 370cc injectors.
I did a seacrh and didnt really come up with much just saw most of it with 550's
If none has done the hack what would be my baseline on tuning down the 370cc's at idle at least
Thanks ahead of time
Re: Has anyone done the AFC Hack on 370cc Injectors (NeXtLeVeL_TyPe_R)
I would start with -30%, which should get you about 7psi if i'm thinking correctly.
If you have an fpr, you could turn up the fuel pressure slightly, that would require a slightly leaner map on the vafc, which would = more room for boost.
I'm running the hack with 370's. With the factory fuel pressure I had mine set between -20 and -25, but I raised the fuel pressure to about 50psi and I run between -25 and -30 on my v-afc. This is good for at least 9psi, I have never thrown a cell, but I've never had the boost past 9psi.
89 CRX SI
02-03-2004 06:01 PM
1.8T_EG
12-09-2003 09:11 PM
