D16 turbo guys? what kind of clutch/flywheel combination are you using
What kind do you have and how does it perform on the street.
thanks in advance
thanks in advance
Re: D16 turbo guys? what kind of clutch/flywheel combination are you using (willyboyD16)
Clutchmasters Al. Flywheel w/ACT Stage 2...works great on the street.
For street use, i would recommend an ACT extremem pp with the street organic disc. It works great and holds the power.
New User
Exedy
Feels like chicken.. ehh errrr... like stock but with 1" grab to engagement pedal play starting when the pedal is all the way down.
And it works great for street.
[Modified by Pritos, 9:24 PM 4/29/2002]
Re: D16 turbo guys? what kind of clutch/flywheel combination are you using (TurboD16Z6)
i have ACT xtreme pressure plate with organic street disc. Works great on the street. No slipping at all, not too harsh either. However i can still chirp 4th
Re: D16 turbo guys? what kind of clutch/flywheel combination are you using (BoostinSOHC)
Using a Clutch Masters (bastids) aluminum flywheel with stage 3 segmented carbon kevlar clutch. Works great after break in.
New User
Re: D16 turbo guys? what kind of clutch/flywheel combination are you using (VTC_CiViC)
D16A6 running ACT HD and street disc. Stock flywheel.
Good pedal engangement and thick A disc. I'd get an exedy next time.
Randy
Randy
Re: D16 turbo guys? what kind of clutch/flywheel combination are you using (RGAZ)
It's not a D16, but a friend runs a similar setup with similar results on a 93 Si.
ClutchMasters 4 puck, single, Stage 5 clutch with PP, stock LS flywheel. Runs like you would expect full race to run... grabs like a clepto, extremely short engagement and lots of clatter if you try to slip it.
*I am putting in a custom Carbon Kevlar stocker (double spring) with CM stage 5 PP and custom cut LS flywheel. Engagement should be smoother with great grab and much longer life than the stage 5. Post results soon !
[Modified by X2BOARD, 12:54 PM 4/30/2002]
Re: D16 turbo guys? what kind of clutch/flywheel combination are you using (X2BOARD)
Stage 2 clutch specialties with full faced sprung disc
Have a clutch specialties 9lb flywheel on the way...
anyone have ACT website. I want to check out some of their packages
1 Post
I'm using an OS-Giken twin plate clutch and OS-Giken flywheel from an FD3S RX7, modified to fit into my D16Y8...
This has got to be the scariest clutch i've ever encountered. Grabs like a bitch, and breaks lots of driveshafts, but its been running in my car for over a year now, and its still working great, not slipping at all, even at 18psi. I just got to be gentle when changing into 2nd gear.. everything else is okay
