high fuel pressure question
Old Apr 30, 2002 | 09:24 PM
zojirushi's Avatar
Default high fuel pressure question
Is it bad to run high fuel pressures constantly? For example around 60 psi at idle? I'm using a walbro 255 lph pump. I will be using a s-afc to turn down the injector cycle duty. So basicly, i lower the injectors alot, then increase the flow by rising the fuel pressure. thanks.
Old May 1, 2002 | 05:17 AM
zojirushi's Avatar
Default Re: high fuel pressure question (zojirushi)
ttt
Old May 1, 2002 | 07:59 AM
BoM's Avatar
BoM
as long as it doesn't exceed the pumps limits, i dont' see any problems.
Old May 1, 2002 | 08:00 AM
b18bturbo's Avatar
Default Re: high fuel pressure question (BoM)
those walbros usually start failing at 100psi plus...
Old May 1, 2002 | 08:06 AM
RGAZ's Avatar
New User
The pump will run hotter and draw more current, but it will work.
Randy
BobbyRodriguez
Aug 18, 2012 12:00 AM
TurboSpoolinInside
Jul 24, 2011 06:06 PM
boosted91REX-SI
Jan 9, 2009 04:52 AM
quikB18B
Dec 18, 2003 06:23 AM
Liquidx02
Mar 16, 2002 08:32 AM
