Detonating already?????????
Old Apr 29, 2002 | 08:35 PM
intekragsr's Avatar
Default Detonating already?????????
Ok, so as you know, i just finished my drag 3 install on my gsr.
When driving low rpm and low gears(1,2 and sometime 3) I hear a little ticking raspy sound, only at around 50-60 percent throttle. But when I step on it, everything sounds normal. This all happens under boost. When I hit around 1 psi it seems to go away Im confused.
Please help me out, thanks.
Im waiting for the car to cool down so I can check the tial wastegate gasket. On my last gsr the gasket would blow out really quickly.
Old Apr 29, 2002 | 08:36 PM
SIK IN DA HED's Avatar
New User
Default Re: Detonating already????????? (intekragsr)
yo man.. that sux. did you install it yourself? that tickin sound could be something else. someone told me that detonation is more like "marbles pinging in a coffee mug".
[Modified by dlplayboy, 9:37 PM 4/29/2002]
Old Apr 29, 2002 | 08:37 PM
dustin's Avatar
Are you making boost in low gears at low rpm at 50-60% throttle?
Does it sound like detonation or an exhaust leak?
Dustin
Old Apr 29, 2002 | 08:45 PM
SEFIxCivic's Avatar
did you retard the timing like your supposed to?
Old Apr 29, 2002 | 08:48 PM
intekragsr's Avatar
Default Re: Detonating already????????? (SEFI8LOxCivic)
I do make boost in low gears.
I dont know if its pinging or exhaust leak since I do not know what they sound like. It is a very faint sound.
Yes I did install the kit myself, and there really isnt much I can do wrong on the install. Its all very straight foward. I have not retarded the timing. I did not know I was supposed to, since the drag install manual told me to leave at stock timing.
Old Apr 29, 2002 | 08:51 PM
dustin's Avatar
I ran 14 deg btdc static for safetey when I didn't have hondata.
It's probably not pinging. How was your downpipe fastened up to the rest of the exhaust?
Old Apr 29, 2002 | 08:54 PM
intekragsr's Avatar
Default Re: Detonating already????????? (dustin)
Just had a muffler shop weld on a flange to connect to the cat. They did a nice job of welding. Im going to go check out the condition of the tial wg gasket. Have you had probelms with it blowing out? Im beginning to think its an exhaust leack somewhere now. I also dont have a gasket on the dumptube. Does this matter?
[Modified by intekragsr, 5:54 AM 4/30/2002]
dustin's Avatar
The tial gaskets suck. I mean really suck. So yes, they do blow out.
Dustin
Old Apr 29, 2002 | 08:55 PM
intekragsr's Avatar
Dustin
What should I do to solve this problem?
dustin's Avatar
Get deltagate gaskets.
Old Apr 29, 2002 | 08:56 PM
intekragsr's Avatar
ok thank dustin Im going to the garage to check everything out.
Old Apr 29, 2002 | 09:42 PM
intekragsr's Avatar
sorry for wasting bandwidth. It was my tial gasket that blew out. Is there anything bad with funky smelling oil? I checked my dipstick and it stank like i never smelled before. Im using mobil 1 synthetic 10 30
Old Apr 29, 2002 | 10:44 PM
Teg4e's Avatar
i'm interested in this....ttt
Old Apr 29, 2002 | 11:02 PM
austrian type-R's Avatar
Default Re: Detonating already????????? (Teg4e)
All the DRAG bolts sux! I have replaced my tial bolts and turbo to downpipe bolts with stuts and copper nuts. Nowit is working. I was sooo frustrated on my tial gaskets,. I have replaced them 3 timen within 3000 miles. Always the dman bolts gets loosen and the gaskets blow. Fix it the 1st time with stuts!
Old Apr 29, 2002 | 11:13 PM
intekragsr's Avatar
Default Re: Detonating already????????? (austrian type-R)
excuse my ignorance, but what the heck is a stut?
Old Apr 29, 2002 | 11:17 PM
SEFIxCivic's Avatar
i think he means "studs"
Old Apr 30, 2002 | 04:26 AM
MiraiZ's Avatar
Yeah..the Tial studs suck ***! I bought some 8mm bolts, some red locktite, and some heat resistant liquid gasket at the local hardware store...problem solved....
as far as the funky smell...are you sure its not gas?...running rich?
[Modified by MiraiZ, 10:29 PM 4/30/2002]
lazyvietboi
Mar 30, 2006 08:24 PM
n1neb4ll
Jul 30, 2003 08:07 AM
lucas569
Sep 3, 2002 12:09 PM
ceemarun
Jul 17, 2002 12:02 AM
