Radiator help for 97 DRAGIII turboed Integra...
New User
I need a new radiator that'll fit with the turbo setup. I remember hearing about the C&R radiators. I basically want something inexpensive. Maybe I should go with OEM. Tell me about some good places to buy from.
Thanks.
Thanks.
Re: Radiator help for 97 DRAGIII turboed Integra... (Anthony K)
www.absoluteradiator.com
Probably the best prices for Koyo/Fluidyne radiators.
I think you'll run into A/C cooling fan placement problems for any larger
radiators. I personally run a Fluidyne, and I have only around 2 1/4" clearance
between the radiator and the turbo. I also didn't have room to mount the A/C
fan as a pusher, because I would have to relocate the stock oil cooler in front of
the condensor. Right now, I don't run A/C usually, and if I do, the car eats up
extra coolant.
extra coolant.
drag 3 lets you keep your stock OEM radiator. You can go with the fluidyne, it will run you $450 plus, they come with 1 slim fan (passenger side) then you use your other OEM fan (driver side). fluidynes rock
New User
Re: Radiator help for 97 DRAGIII turboed Integra... (GudeH23a)
