Resistors
Old Apr 28, 2002 | 11:23 PM
ion_four's Avatar
Default Resistors
Q1: I think I know what a resistor pack does...(lets you use peak-hold instead of saturated, by adding more resistance) they're on older Hondas...but, can I just put some resistors in series or even parallel?
Q2: If I put some potentiometers inline with the map sensor, I could do the same thing that the V-AFC does as far as running larger injectors, but would it also cover up the boost signal from the ecu and not through a code?
silverCRXTC
Feb 4, 2004 07:32 AM
0 0 0
Jan 15, 2004 07:48 PM
turbo90crx
19
Oct 28, 2003 05:44 PM
leadtrum
Jun 18, 2003 07:55 PM
wickedxboi
Sep 10, 2002 02:56 PM
