Downpipe size?
Old May 1, 2002 | 01:54 AM
ion_four's Avatar
Default Downpipe size?
I've seen a couple posts and sigs with people using a smaller downpipe than exhaust (ie. 2.5" DP and 3" exhaust). I'd think the optimum would be to have the DP be the same size or bigger than the exhaust, or is that not right? More to the point...I've got a 2.25" cat-back(possibly with test-pipe) now and will soon be going turbo with a 2.5" downpipe. Is this a good DP for the exhaust I have?
Old May 1, 2002 | 01:58 AM
degradated's Avatar
New User
Default Re: Downpipe size? (ion_four)
Most guys won't have a full 3" downpipe because it interferes with the A/C compressor, so you would have to remove that to go full 3" (at least that's what they say, when I took a look down there, I personally didn't think it would interfere).
Yes, full 3" is idea if you can do it, but a 2.5" into 3" downpipe with 3" test pipe and exhaust is almost as good, and probably all you need.
Old May 1, 2002 | 02:08 AM
ion_four's Avatar
Default Re: Downpipe size? (degradated)
AHH, that makes sense about the AC...I'm still not 100% how I'll be able to keep mine when I do my install. I think I might have to go to a slimline fan, at the least. I'm planning on going ghetto with the STD civic manifold and a T25...any idea how far that will stick out from the block? I've got about 7" with the fan installed between the core and the block, and 10" if I take it off and get a slimline in front of the core. I was thinking it might be possible to have the compressor on the passenger side, like the Apex'i kit, among others, so I can keep it away from the compressor, any ideas if this works?
a267mm
Welding / Fabrication
May 29, 2014 09:56 AM
crex23
Dec 11, 2004 06:01 AM
asianspeed
Nov 28, 2004 02:45 PM
b_ron007
Oct 28, 2004 01:49 PM
cjb80
Feb 18, 2003 08:44 AM
